Bass management
robert p
robert p Posts: 12
My Home theater Pre-Amp no matter what I do to it when I program it to integrate all the speakers robs my front speakers of there bass .What is the problem how do I eliminate this
Post edited by robert p on
    edited August 2012
    We could better answer that if we knew your gear....how many and what kind of speakers,what amps, etc.
  • robert p
    robert p Posts: 12
    edited August 2012
    I have an Outlaw 990 preamp a Levinson model no 23 power amp ,Rotel 993 3 channel amp,set of Maggie 1.6's set of Von Schwek VR 4II's a Martin Logan Depth Subwoofer and a paradigm center channel speaker.I also have a V.P.I. Scoutmaster table and a Rega Apollo CD player and a MSB Platinum Dac all M.I.T. cables
    edited August 2012
    So which is being robbed of it's low end ? Not that they should have that much anyway since you have a subwoofer in the mix. Where is your crossover set at and have you played around with different settings ?
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited August 2012
    Not to be glib - but isn't 'bass management' by definition 'robbing' the mains of the dangerous scary and harmful bass signals so that the sub can handle it?
  • Rivrrat
    Rivrrat Posts: 2,101
    edited August 2012
    What do you have the mains crossed over at?
    My equipment sig felt inadequate and deleted itself.
