Wondering about stuff
snake1
snake1 Posts: 567
edited August 2012 in Electronics
Hey crew,
Got some questions and this seemed the best place to put them. Started my setup with the 12's in my sig and a yamaha rx-v371, which was scraping the barrel and not pushing much at all but it would get loud. Well, to get a better foundation for a nice surround system in the living room I moved up to the Onkyo. Since getting it I bi-amped the towers and ran the audyssey setup. Strangely it seems weaker (in the bass and overall volume dept.) than the yamaha in some ways.... I guess I was expecting more from the added power of the Onk. Any ideas??
I realize that an amp would cure this problem but I'm not diving into that yet. Any adjustments that could be made?
I'm also going to add a sub to the mix which will help as well I'm sure.
The next move I'm going to make is a UPS back-up and power conditioner. My projection TV, PS3, and Onk need more protection than that powerstrip! What do you guys think?
AVR - Onkyo NR809
500gb HD for MP3 and FLAC files
Amp - Parasound 2250 - FOR SALE BTW!! PM me if interested!
Mains - Polk RTi12 towers
Center - CSi5
Surround - FXiA6's
Sub - psw505
Movies and games - PS3
TV - Toshiba 52" HD
Every vehicle has one good nuetral drop in it
Post edited by snake1 on
  • chumlie
    chumlie Posts: 8,658
    edited August 2012
    I would use a good set of jumpers on the speakers. Not getting much benefit biamping a reciever. Power conditioner: APC H15.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2012
    Good move on the Onk 809 since you have pre amp outputs. Think about an amp in the future to drive the 12's with, first try above the Brass Bars on the speakers can be an issue with sound. Bi-amping the onk wasn't a good move that didn't give you any move output over one.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • snake1
    snake1 Posts: 567
    edited August 2012
    So swapping back over to single hooks with jumpers attached may make a difference?
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • chumlie
    edited August 2012
    Quality jumpers. Yes.
  • snake1
    snake1 Posts: 567
    edited August 2012
    Ok, they are the gold jumpers that came with the polks. I'll give it a shot tomorrow.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • chumlie
    edited August 2012
    You would be better off making you own jumpers out of quality wire than useing stock jumpers that came with the speakers.
  • snake1
    snake1 Posts: 567
    edited August 2012
    Ok, jumpers are back on and not much diff if any... oh well. Any other ideas are welcome.
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
  • snake1
    snake1 Posts: 567
    edited August 2012
    One question, would turning the ohms down to 4 instead of 6 help the volume or bass issue?? I'm very ignorant to the aspect of impedence as well!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
    edited August 2012
    snake1 wrote: »
    Nope, leave it at 6.
    Make sure none of the plastic coating on the speaker wire is caught inside a binding post on either the receiver or speakers. Check in your receivers menu what the speaker levels are set at. Start at 0 and adjust from there.
  • snake1
    snake1 Posts: 567
    edited August 2012
    Cool, left it at 6. I got the cd manual out last night and went through all of the adjustments and got it where I like it now. Upping the input signal from each source has helped greatly! Still have more adjusting to the EQ but def got a LOT better yesterday! Thanks fellas!
    AVR - Onkyo NR809
    Center - CSi5
    Surround - FXiA6's
    Sub - psw505
    TV - Toshiba 52" HD
