Another common ground question
13»
  • jimbo1421
    jimbo1421 Posts: 772
    edited August 2012
    Thanks F1nut. NAD okayed strapping the negative terminals together to create a good common ground. Actually they said I could strap all 5 channels together, although I only wanted to connect the fronts this way. I will find out tomorrow if I can just do the front two. I have set it up strapping the 5 with spade terminals and bananas for the speakers. Stuffing two spade terminals into a binding post is a tight, clumsy fit and I don't want to leave it that way.
    Thanks for your help. I will be writing more about this amp in the other thread, http://www.polkaudio.com/forums/showthread.php?134846-NAD-T-955-A-good-choice-for-SDAs
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
    F1nut Posts: 51,777
    edited August 2012
    So, it really is a non-common ground amp.....interesting. Anyway, I'm glad you got it sorted out and can now enjoy your system.
  • jimbo1421
    edited August 2012
    Well, the manual describes the T955 this way:
    The NAD T955 houses five individual amplifiers, each on separate
    circuit board. Each amplifier channel acts as a ?mono block? within
    the chassis. Each input connector, and set of loudspeaker output
    terminals, is directly connected to that channel?s circuit board.
    This design eliminates extra wiring and keeps signal paths short.
    Furthermore, this modular design increases reliability and thermal
    efficiency. The input circuit uses a totally new dual differential input
    topology that operates in true Class-A mode. The special Holmgren?
    toroidal transformer has less hum and magnetic leakage than
    conventional toroidal transformers, but retains the usual benefits of
    high efficiency and high power-to-weight ratio.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
