Another common ground question
Thanks F1nut. NAD okayed strapping the negative terminals together to create a good common ground. Actually they said I could strap all 5 channels together, although I only wanted to connect the fronts this way. I will find out tomorrow if I can just do the front two. I have set it up strapping the 5 with spade terminals and bananas for the speakers. Stuffing two spade terminals into a binding post is a tight, clumsy fit and I don't want to leave it that way.
Thanks for your help. I will be writing more about this amp in the other thread, http://www.polkaudio.com/forums/showthread.php?134846-NAD-T-955-A-good-choice-for-SDAs
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
So, it really is a non-common ground amp.....interesting. Anyway, I'm glad you got it sorted out and can now enjoy your system.Political Correctness'.........defined
President of Club Polk -
Well, the manual describes the T955 this way:The NAD T955 houses five individual amplifiers, each on separate
circuit board. Each amplifier channel acts as a ?mono block? within
the chassis. Each input connector, and set of loudspeaker output
terminals, is directly connected to that channel?s circuit board.
This design eliminates extra wiring and keeps signal paths short.
Furthermore, this modular design increases reliability and thermal
efficiency. The input circuit uses a totally new dual differential input
topology that operates in true Class-A mode. The special Holmgren?
toroidal transformer has less hum and magnetic leakage than
conventional toroidal transformers, but retains the usual benefits of
high efficiency and high power-to-weight ratio.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro
