Remove PR's & Drivers Previously Mortited
JMSSDA2B88
JMSSDA2B88 Posts: 13
edited August 2012 in Vintage Speakers
A little over 2.5 years ago, I replaced the gaskets with mortite on my SDA 2B Studio's. I just purchased a set of Larry's rings and want to install them with Armacell for the gaskets. I am having a hard time removing the PR/drivers to start the process. I have pushed from the back through the binding cup but the PR is not budging. I have tried the curved paint can opening tool from the front but that doesn't seem to be working (I have been gently using it). I don't want to do something that will cause any damage. Any advice from those of you that have done this before? Thanks!
Jim
Post edited by JMSSDA2B88 on
  • gdb
    gdb Posts: 6,012
    edited August 2012
    Put em up in a 125 degree attic for an hour or so..............then......try the push from inside, if that doesn't work, get a helper and try prying from four points around the circumference all at once. Next is a pneumatic air chisel............:eek:
  • gdb
    gdb Posts: 6,012
    edited August 2012
    Actually, if they're that well unified with the baffle, why mess with it? You've got the ideal coupling already. :wink:
  • 11tsteve
    11tsteve Posts: 1,166
    edited August 2012
    i laid my speakers on their backs and gently but firmly pulled with a needlenose on a bit of the basket ring which stuck out just a hair past the front surface. very slow, very careful.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
    F1nut Posts: 51,763
    edited August 2012
    Push harder from the inside and have someone in front to catch it when it pops.
  • JMSSDA2B88
    edited August 2012
    With the space between the drivers, I was able to get them out with the paint can opening tool. I will try pushing harder on the PR. Now I can come in from the back or above from the drivers. Just need to get more leverage!
    nooshinjohn Posts: 25,917
    edited August 2012
    This is why Mortite is an epic failure IMHO and should no be used... ever. Armacell is better at sealing, easier to work with and allows for easier removal of drivers later. I cannot remember whp it was that made new seals for the speakers, but those would be the best choice IMHO. While you have them out, clean up that Mortite mess and use something else.
  • JMSSDA2B88
    edited August 2012
    I know the coupling is pretty good, but I want to put some dynamat on and also some JB weld on the driver magnets. I purchased these back in the fall of 88 (in Mesa, AZ) and they have been moved many times and we are now in Virginia. The magnets have not shifted but I don't want to temp fate.:cheesygrin:
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2012
    John you are certainly spot on with the Mortite comment. Why that became such a hot idea I'll never know or understand.
    Toolfan66 Posts: 18,052
    edited August 2012
    There is one thing that came out of using Mortie and that is the rings. The Mortite put too much pressure on the threaded inserts on my 1.2tl's and would slowly want to pull them through the partical board that was my initial reason for designing the rings, little did I know at the time they would do more..
    Mortite sucks!! get rid of it and use Armacell or new gaskets if you can find them as John stated above..
  • ken brydson
    ken brydson Posts: 9,002
    edited August 2012
    That sounds wrong on so many levels....:cheesygrin:
  • gimpod
    gimpod Posts: 1,793
    edited August 2012
    And like giving birth don't forget to breathe:razz:
  • JMSSDA2B88
    edited August 2012
    Update. I tried to push the PR harder from the rear and from the drivers without success. Even tried to use the needlnose plier suggestion. Over dinner I thought of using a couple of pieces of wood in a "T" shape. I used a 2x4 (about a half inch longer than rear of cabinet to PR) nailed to a 1x6 and inserted the 2x4 section into the speaker. The 2x4 is wide enough so I wdidn't worry about it slipping and going through the PR. I then used 2 clamps on each side of the speaker to pull the "T" forward and push the PR out. I do plan on using Armacell since I don't want to have to do this again.
    Thanks for the advice.
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited August 2012
    I bet this thread has got a lot of people's knees shaking. Glad I bought extra gaskets from Brgman.
  • nspindel
    nspindel Posts: 5,343
    edited August 2012
    JMS, sorry to hear about your troubles. Personally, i'm very glad that I avoided this Moretite fiasco and went with Armacell from the start. Good luck getting this sorted.
    edited August 2012
    Do you have access to dry ice? Just thinking that if that crap can be frozen, it might make it easier to crack loose.
  • dorokusai
    edited August 2012
    The Mortite was always a bad suggestion but that's neither here nor there at this point. Have you seen the "dental" pick tools kit you can buy from Home Depot? Since you can get at the radiator from the rear, somewhat at least, use the picks to remove any Mortite that is "leaking" around the edges. Your best bet is to get an edge to pop from behind, after that you're fine but DO NOT pry from the front baffle.
    My second suggestion is to get a short handled, STUBBY, flat head and pry using that from the rear. OR a long handled flat head, that protrudes enough out of the binding post hole to tap on it with a rubber mallet. Basically what you have is cement now but it will release in larger patches once you get some leverage.
    You're not going to get anywhere trying to bang it out as a single unit, so try to hit it corner by corner.
    The last suggestion I can say is use the picks to use the mounting hole points and try and pry, towards the metal frame. Get the pick end under the frame hole, and pry inside. Does that make sense?
  • dorokusai
    edited August 2012
    Don't start using dry ice, period. That's the worst suggestion ever and this is not at that level. It's simply a psuedo-cement issue vs proper leverage.
    edited August 2012
    dorokusai wrote: »
    I have used dry ice in the past for taking linoleum tiles off the floor and it worked better than anything else I tried. I have never used it in an application like this however...
    Just thinking out loud with it, but thinking more, it may not be very good for the surrounds.:redface:
  • 11tsteve
    edited August 2012
    i did try the flat head screw driver to start and ended up replacing the PR because it slipped and i went through the surround.
    just be very careful and slow.
    Polk Lsi9
    Keces DA-131 mk.II
  • gdb
    gdb Posts: 6,012
    edited August 2012
    Heat will soften it just fine. if you don't want to attempt the 125degree attic approach, try the judicious use of a hair dryer. It will take a long "soak" to get everything up to a warm enough temperature but, the freakin thing will release without the need for a catcher! The originator of the Moretite idea ? Yeah, that was Matthew Polk.:wink:
  • dorokusai
    edited August 2012
    You've never used it in this application but what a great suggestion for a complete stranger to use, and who's gear you could only have a cursory care for....awesome. I'll add you to the top of my list of Xmas cards for 2013 and it's just not a good idea overall John. It's certainly out of the box I guess.
    edited August 2012
    dorokusai wrote: »
    Don't I get any credit for being the originator of the use of Armacel? I do care about his gear btw, but I will do a better job of fully thinking my ideas through from now on.:redface:
  • skrol
    skrol Posts: 3,450
    edited August 2012
    A small L-shaped hex key and pliers work great. Slip the short end of the hex key in the gap between the driver and the cabinet. Twist the hex key with the pliers to hook it under the driver. Pull the hex key outward with the pliers. This works without leaving a mark on the cabinet or edge of the driver.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    F1nut Posts: 51,763
    edited August 2012
    Guys, he already got it out.
    dorokusai wrote:
    The Mortite was always a bad suggestion...
    I never thought it was a good idea, but Matt Polk did.
    edited August 2012
    Did you use Mortite or something like Mortite? I'm only asking cause I never had an issue pulling my drivers and passives out..
  • dorokusai
    edited August 2012
    That's just an odd suggestion John. Armacell and other foam or mastics were being used on other forums before they came here to be popular. I believe the modification insanity of CP was a lack of folks that were already doing these things passing on the information and sharing knowledge. I keep my work private, always have and kept my mistakes and successes to myself. That being said, this forum is responsible for a number of notable pieces of excellent work and truly unique ideas that would only be on Polk speakers. Just another reason this place is so awesome
  • dorokusai
    edited August 2012
    Yeah, he also thought the Monitor9 was a great idea but the reality of it was the fact Polk had to use up a bunch of drivers they couldn't use in any other design at the time. Not every idea is awesome and I make my own moves when it comes to upgrades and modifications, don't you? I know you do F1Nut, if anyone does....c'mon now lol.
    F1nut Posts: 51,763
    edited August 2012
    Toolfan66 wrote: »
    Larry, against my better judgement I tried Mortite on my 4.1TL's. I noticed that the bass didn't sound as good/deep as it did with the stock gaskets, so the Mortite was gone in a flash. I didn't have any trouble removing the drivers/PR's, but I did have to work at getting it off the metal baskets. IIRC, this was done before the rings were installed.
    F1nut Posts: 51,763
    edited August 2012
    dorokusai wrote: »
    No argument from me on that one...was just pointing out where the idea came from.
  • dorokusai
    edited August 2012
    Yeah I believe that direct suggestion was expounded upon in another thread and it quickly took root and became a mind of its own. It's a tweak, like any other and sometimes they turn out awesome and sometimes it takes time to see what the final outcome is....it happens. This is by far the most extreme issue so far and it appears he's ok now.
