Polk Audio SDA SRS 1.2 Crossover Modification Thread
VR3
I have been wanting to do one of these since I started doing this so this will be fun!
Clarity Cap ESA (Tweeter) SA (Woofer/SDA), Mundorf Resistors, GIMPOD boards, upgraded SDA inductor, NL2 SDA outs (owner has a dreadnought), upgraded binding post
Will be fun!
Will be fun!
Post edited by VR3 on
I can't wait :razz:POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Why the NL2's?
Is it because your customer's dreadnought is already setup with them, or do you find them to be superior to a good set of binding posts? -
NL2 fits in the old SDA connection better (its larger than the original hole) and I find the connection be far superior to binding post, IMO.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Are they tl's? Or are you going to do a TL mod?
We are not doing a TL mod - the SL2000 is going to be replaced with RDOs- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
For the cost of replacing the two inductors on the board and using the RDO-198's is a no brainier IMO...
The biggest concern was wait time and after talking with Polk's CS we felt it would not make a big enough difference considering we were using RDO replacements.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
True about wait time on the inductors but they are worth it...
I hear ya... I had to wait 2 months + for the inductors that should be here in a few days... thats alot of time with no tunes!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Better order mine now since it will be about 2-3 months when I do the crossovers. :razz: -
True true!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I had to be a little creative on this one
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Beautiful work Trey!:eek:
I hate you!
Good Day!
Testing
Testing
Testing -
Just laying them out like that is a job in itself, and another fine example of why I hate you!
For those not in the know, I am just ribbing Trey, but only because I am jealous!
There, I said it, you happy?
Testing
Testing
Testing -
Thanks Peppy!!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Progress- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Hmmm, SDA inductors will be here eventually - going to ship using the stock inductor for now
Just gotta do the SDA cables and Nl2 connection on the plate, test, pack, ship!
DUN DUN DUN!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
So did you end up tl'ing them?
Do you use zip ties instead of hot glue for later replacement?
No tl
There is a run of hot glue under each component + zip ties
Testing testing- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I think I recognize those crossovers!
