-3dB Limit
Belling
Belling Posts: 12
edited May 2004 in Speakers
If a speaker's overall frequency responce is listed as 50hz-27khz but the lower -3dB limit is 60hz, does the speaker go down to 50hz or only to 60hz? Why the difference?
Post edited by Belling on
    F1nut Posts: 51,722
    edited May 2004
    Yes, it goes down or up to the rated frequency response. The -3dB rating is where the frequency starts to roll off.
  • PolkThug
    PolkThug Posts: 7,532
    edited May 2004
    Yes, it will play 50hz, but at a much lower volume.
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited May 2004
    The overall limit is usually -10 dB, but not always.
    Also, the volume at which the speaker can deliver the rated F3 is important. It should be able to do it at realistic levels.
    SVS
  • Belling
    Belling Posts: 12
    edited May 2004
    Thanks guys. I THINK that i'm beginning to understand.
