Resist the itch!!!!!
jon1redleg
jon1redleg Posts: 242
edited August 2012 in The Clubhouse
I went to the Farm this past weekend to set trail cam for up coming deer season, i also shot my .22 cal rifle,
AR15, done some fishing and ended my day with a rip around the woods on 4 wheeler.
Well I didn't catch any fish to bring home but did manage to bring home a large number( VERY LARGE !!) number
of turkey mites!!!!:evil::evil:. I almost always spray down but this time I had a good ol B RAIN ****!! and
now I have well over a dozen bites and the itch from HELLLLLLLL!!!!
I have tried every thing to control the pain and itch, lic shampoo,anti itch cream, etc... all but smashing
my big toe with hammer to keep mind off it.:razz:
Never again will I forget to spray down.
Any suggestions?
Post edited by jon1redleg on
  • littlewoodboats
    littlewoodboats Posts: 823
    edited August 2012
    My dogs get into things they should not out here it the woods. One of the best things I have found for critter infestations is Aloe Vera sunburn gel.
    The lidocaine kills the itch with the gel suffocating the bugs. Normally clears up my pound hound in a day.
    Hope it helps.
    F1nut Posts: 51,778
    edited August 2012
    Gasoline and a match should take care of it......
  • littlewoodboats
    edited August 2012
    This should work much faster than my suggestion. Be careful to not spill any of the gas on the ground to avoid issues with the EPA or Sierra Club.
  • jon1redleg
    edited August 2012
    LEADED OR UN-LEADED? AND SHOULD I STRIKE THE MATCH IN SIDE THE HOUSE OR OUTSIDE?:cheesygrin:
  • littlewoodboats
    edited August 2012
    jon1redleg wrote: »
    This would most likely only apply to someone old enough to not have hardened seats. Should probably check your manual.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited August 2012
    A lot of people get soft seats when they get older:lol:
  • jon1redleg
    edited August 2012
    PolkieMan wrote: »
    your coments have me scrathing my seat!:cheesygrin:
  • littlewoodboats
    edited August 2012
    PolkieMan wrote: »
    Quite true. I would think a softening of the seats would indicate an out of spec condition requiring correction prior to addressing the gas issue. Looks like the bug cure will just have to wait.
    tonyb Posts: 33,072
    edited August 2012
    Play some Willy Nelson.....them bugs will run like hell.
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited August 2012
    I think you just found the other use of a soldering iron. Use the high setting.
  • jon1redleg
    edited August 2012
    tonyb wrote: »
    Now ya see I thought they liked Willy.... after all I did get them from weed (oops I mean weeds!):biggrin:
  • littlewoodboats
    edited August 2012
    jon1redleg wrote: »
    Having met Willie I am not sure he always knows the difference either. Honest mistake.
  • soundfreak1
    soundfreak1 Posts: 3,414
    edited August 2012
    Ice pick, or calamine lotion the later is less painfull
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • littlewoodboats
    edited August 2012
    The gas talk is funny. I remember being a scout back in the 70's with a requirement to bring a bar of Fell's brand Naptha soap to any camping over occasion. It would light with the standard Scout Hot Spark.
    Troop 10 out of Cape Girardeau Missouri. Rush Limbaugh's grandfather was one of my scout masters. Rush Senior.
    Try the sunburn gel as it does work.
  • rpf65
    rpf65 Posts: 2,127
    edited August 2012
    Met Willie a couple of times, he's a good guy. Don't care for his music, but he is good people.
    As far as your "uncomfortable" condition, an old time remedy is vinegar. Seems to help on most bug bites.
