New to Polk Audio Questions
Bass12
Hello I'm new here and was wondering what are some good receivers with a low price tag for the PSW505. Thanks.
Post edited by Bass12 on
Welcome to Club Polk.
You should get the receiver that has all the bells and whistles that you want it to have and make sure it has preouts so that you can upgrade the amplification. It will cost you more money, however it will also last a long time without having to upgrade the receiver.
It is better to wait, save more money and get something that gives you better options then to simply go with what is cheap but you end up spending it all over again the following year.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Thanks for the advice and I appreciate it.
+1 on what cfrizz statedHome Theater
Two Channel
Oppo 105D BAT VK-500 w/BatPack SDA SRS 2.3 Dreadnought Squeezebox Touch Apple TV -
welcome to the club
