New to Polk Audio Questions
Bass12
Bass12 Posts: 3
Hello I'm new here and was wondering what are some good receivers with a low price tag for the PSW505. Thanks.
Post edited by Bass12 on
  • cfrizz
    cfrizz Posts: 13,415
    edited July 2012
    Welcome to Club Polk.
    You should get the receiver that has all the bells and whistles that you want it to have and make sure it has preouts so that you can upgrade the amplification. It will cost you more money, however it will also last a long time without having to upgrade the receiver.
    It is better to wait, save more money and get something that gives you better options then to simply go with what is cheap but you end up spending it all over again the following year.
  • Bass12
    Bass12 Posts: 3
    edited July 2012
    Thanks for the advice and I appreciate it.
  • zane77
    zane77 Posts: 1,696
    edited July 2012
    +1 on what cfrizz stated
    Two Channel
  • whitecamaross
    whitecamaross Posts: 219
    edited August 2012
    welcome to the club
