PIONEER ELITE SC07 preouts issue
doggie750
doggie750 Posts: 1,160
edited August 2012 in Electronics
Hello Polks,
Shout out to the ICE club peeps here, my original SC07 was stolen when I had it service for firmware upgrade. The authorized service center replaced it with a used one with 1month warranty. So now I am screwed, most of the preouts are F>>King loose, no signal coming out (you have to move it around 'till u can achieve signal) I assume this came from a store and ran as display and abused. Seem like the fools from the store dont know how to use the interconnects correctly.
Panel was removed to investigate but it aint service friendly, covered with IC boards, so seeking some advice here. I guess i can disconnect some IC boards to gain access to the connectors and resolder.....:question:
Godspeed,
D0661E
AVR:Pioneer Elite SC-07
Surrounds: RTis
2channel:Rti100 (carver driven
Sub:SVS PB12-Plus/2
Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
Wsrn:Hitachi ultra vision LCD60, 32XBR400
PowerConditioner: MonsterC HTS5100
PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
Odyclub; Xsimulator; Sony; Zune; Canon
Post edited by doggie750 on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited August 2012
    It seems to me that you're correct they need to be resoldered. Could you do this? If not resend it back to fix them.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    F1nut Posts: 51,760
    edited August 2012
    Tell them you want cash, not the piece of junk they are trying to pass off.
  • gfong
    gfong Posts: 1,079
    edited August 2012
    If it's a service center can they not fix it to at least the shape yours was in when they recieved it? I would also look into cash as it sounds like you got the worst end of this deal. They just happened to have one on the shelf eh! hmmmm. :)
  • doggie750
    edited August 2012
    Unfortunately, 1month warranty has been passed. They'll charge $50-60/hr to fix depending on the case. As noted, I am screwed. Been watching movies w/o my amps and sub :(
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
    pitdogg2 Posts: 27,040
    edited August 2012
    better business bureau is your friend they gave you a lemon and they knew it they should work with you.....
  • blairfrischx
    blairfrischx Posts: 259
    edited August 2012
    Just think of it as building appreciation for your system? :cheesygrin:
