Oppo DV-980H
stretchl
I've been reading a bit about these and I have a couple of questions I wonder if someone here might answer -
1) I would like to play DVDs to our TV via HDMI, but CD's into my Luxman R-115, which doesn't have HDMI. Is it possible to wire the DV-980H to do both?
2) If so, does anyone have one they want to sell?
Thanks!
Thanks!
“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
- Isaac Asimov
Hi-Fi
Visuals
Post edited by stretchl on
Pretty sure you can do that.
Just a settings thing i believe.
I may have one back there.I have an old oppo i dont use but not sure the model.
I'll look.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Thanks, mon.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
http://Vimeo.com/channels/stretchphoto -
Yep it's possible. I do that with my Oppo. I have it connected to my Plasma via HDMI for DVD's, then have RCA cables connected to my preamp so that the audio portion comes out my speakers. When I'm watching DVD's I have to "mute" my tv then change the selector on my preamp.
Sweet. Thanks!“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
