Any thoughts on Max Fidelity
jimsvm
jimsvm Posts: 307
edited August 2012 in Electronics
Hay all tube junkies. I want to power up the new to me Monitor 10's with an intagrated tube amp by Max Fidelity. Therrr is a local dealer in my area. Woundering if anyone has had a listen to Max tube pre. Thanks for looking
Jim
Rec rm vm30 micro pro 3000 akai 2 channel. ht anthem MTX 5 channel anthem P2 statement anthem 325, 8 channel Martin Logan power amp for 4 ceiling ls900 2 and outdoor polks, 2 JL 110’s subs panasonic 65" plasma lsim 705’s , 706c, L200 and Control 4 garage rig monitor 10s crossovers by VR3, dynamat, RDO-194's, new drivers. psw 111 Pioneer 9040 BDP53fd 100 " screen Nakamichi HD projector, and Panasonic 65” plasma.
Post edited by jimsvm on
  • brgman
    brgman Posts: 2,859
    edited August 2012
    Honestly never heard of them.
    I’M OFFENDED!!!!
  • jimsvm
    jimsvm Posts: 307
    edited August 2012
    Found out that the Max Fidelity is manufactured in toronto by The Speaker Shop. The dealer in my area will bring over a couple of different amps to listen to. Is there anything in particular is should be looking for. Thanks
