F/X Wireless for 11.2 setup?
pearsall001
pearsall001 Posts: 5,242
edited August 2012 in Speakers
I'm currently running a 9.2 system & BD movies sound incredible. I have the capability of expanding to a 11.2 system with my Yamaha RX-A3010 AVR. Just curious on your thoughts about using the F/X wireless instead of adding a pair of speakers to the rear wall. I would definetely save me the hassle associated with hooking up another pair of speakers (very long run thru drop ceiling) a big pain in the arse. I don't think timbre matching is too critical for the rear or front presence speakers. I have Def Tech for my front presence & KEF's for the rest of the system. No issues with the Def Techs along with the KEF's. I'm sure the F/X would be the same with blending in. Thoughts.
Post edited by pearsall001 on
  • pearsall001
    edited August 2012
    Hmmmm! No one using the F/X wireless to chime in & give their thoughts.
  • nwohlford
    nwohlford Posts: 700
    edited August 2012
    I have played around with it in a system to make a 3.1 into "7.1" where I had no intention of running wires. I am not a huge surround sound person, but it seems to work well for movies. I have had many of the same issues as others with the auto turn off feature and the sound that goes along with that (this is more of an issue with TV where there is very little sent to the rear channels and you do have to be careful about other 2.4 Ghz networks). I think somebody posted recently about Polk having a replacement transmitter, but I have not checked into that.
  • pearsall001
    edited August 2012
    nwohlford wrote: »
    I've read about that issue & the new transmitter Polk sends out seems to correct the problem. I wonder if it's an all together newer version that fixes the issue.
