TL2: where to find wall a support
cyberico
cyberico Posts: 1
edited August 2012 in Speakers
hi, i bought 2 TL2 speakers but no bracket is included on the package so i really dont know where to buy a small almost invisible support to install it on wall.
can you suggest some products (url, pictures..) that suit TL2 speaker? thnx a lot
  • unclebump2008
    unclebump2008 Posts: 10
    edited August 2012
    The TL2 comes with a keyhole slot on the back. Just leave the proper sized screwhead sticking out of the wall. Otherwise you need to use a wall mount bracket with a 1/4-20 stud
