Hope to hook up LSi15's in a couple of days
stretchl
Im now driving back to Illinois with a pair of LSi15's in the back seat of my car. My Adcom GFA-555ii should be there by the time I arrive.
After I get some under-the-floor measurements done, I'm going to get some new speaker cable from Frank at Signal Cable. But I will sure want to hook things up in a temporary fashion before I get those measurements done and that cable in. So...
The posts on the back of the LSi's look different that those on the 10b's, for which I just use bare ends of Radio Shack stereo cable.
Is it possible to use this wire on the LSi's? If so, how? Do the posts on the LSi's unscrew somehow that I'm not seeing?
Thanks very much.
Sign me, "Chomping at the Bit"
Thanks very much.
“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Cabling by Groneberg
Visuals
- Isaac Asimov
Hi-Fi
Visuals
Post edited by stretchl on
Shouldn't be a problem. The LSi's have a hole in the middle of the binding post. Unscrew the top piece till you can thread the wire through that hole and then screw it back down. Done"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Thanks Ender there are two pairs of posts. Does it matter which I use?“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
http://Vimeo.com/channels/stretchphoto -
Do you have the brass jumper that connects both sets of posts? If not you will need a short run of wire to connect to the other set of binding posts your speaker wire isnt in like below
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I don't have the jumpers. Should I order a set of these from Signal Cable, also?
Meanwhile, I'm guessing I can just use a short piece of speaker wire?
Thanks.“Anti-intellectualism has been a constant thread winding its way through our political and cultural life, nurtured by the false notion that democracy means that 'my ignorance is just as good as your knowledge.'”
- Isaac Asimov
Hi-Fi
Visuals
Yes, a short piece of wire will work perfectly.
And you could either have Frank make you jumpers or have him make you bi-wire speaker cables either works"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
