Opinions & Info SDA 1B
chumlie
chumlie Posts: 8,658
edited July 2012 in Speakers
Local craigslist has a set for $400. Says excellent cond. Couple of questions for all you SDA guru's.
Hows the price ?
Can these be hooked up to my Parasound HCA1500a without modification ?
Anything i should lookout for, being there used ?
    heiney9 Posts: 25,667
    edited July 2012
    Do you have photo's to confirm they are 1B's? Are they truly "excellent" cond?
    $400 is about an average price for good cond 1B's with the cable, etc.
    Can't answer if the 1500a is common ground, but 1B's can't use the AI-1 interphase so keep that in mind if it becomes an issue.
  • chumlie
    edited July 2012
    F1nut Posts: 52,365
    edited July 2012
    Yep, 1B's.
  • PolkieMan
    PolkieMan Posts: 2,446
    edited July 2012
    one tweeter looks pushed in. Is the interconnect cable pin/blade or blade/blade probably blade/blade so yea 1B's. Offer $350.
