Windows XP Install CD
rtart
Hi folks,
I've got a few Win XP based PCs around but they all have OEM installed operating systems and I don't have the recovery disks. Anyone have an install CD?
I have the correct (and legal) activation codes, just need the discs. Of course, if you have a copy with codes that's even better.
Thanks!
Thanks!
My 7.4.4 DIY 4k Home Theater:
Polk LSiM 707 L-C-R, LSiM702 side surrounds, LSiM 703 rears
Polk LSiM 702s x 4 on the Ceiling Atmos speakers
Subs: Eminence NSW-6021-6 tuned to 14Hz, NX6000D (front),
2 x SVS PB12/Plus 2's (rear) miniDSP HD2x4
Denon X3700H Emotiva XPA11 Gen 3
XBox One X 4k & BD and streaming
Panasonic UB-420 4k player
HD-A35 HD DVD
Oppo BD-103D for hirez audio
Technics SL-D2 TT, Grado Gold Cartridge
JVC DLA-RS2100/NZ7 projector
Silver Ticket 135" microperf AT screen
Berkline 090 electric recliners with Aura Bass Shakers
HD-A35 HD DVD
Post edited by rtart on
i have a dell xp and and xp pro disc without codes if that would do you any goodHello Kitty am/fm CD player
Might. One of my PCs is a Dell Optiplex 745.
$$$?My 7.4.4 DIY 4k Home Theater:
HD-A35 HD DVD
Berkline 090 electric recliners with Aura Bass Shakers -
i think priority mail is about 6 bucks, would that work? lolHello Kitty am/fm CD player
Highway robbery :-)
Very kind of you. I sent you a PM with my PP ID so you can send me a money request, or I can send funds to your PP ID if you send it to me.My 7.4.4 DIY 4k Home Theater:
HD-A35 HD DVD
I may have a set of non-proprietary discs(dell, hp, etc.) left over from a custom build that I did several years ago. If you are not able to get help from other members, let me know and I will look for them.
Thanks. I've already got a set of Dell discs on the way, but yours might work better. I'll take them if you can dig them up.
Please PM me your PP ID and I'll get funds to you.
Thanks!My 7.4.4 DIY 4k Home Theater:
HD-A35 HD DVD
Just an FYI, those Dell/HP/OEM discs will work on any PC (they aren't propriatary at all). I've used my Dell disc on numerous PC's. If I recall, it did create a Dell folder somewhere, but it didn't affect anything.
Basically it's the license you have to worry about. OEM license needs a "branded" disc. True XP licenses need a real MS CD. Hope that helps!
Oh - if activation fails and it wants you to call, go ahead and do it. The automated system will give you an activation code once you tell them this windows install is only on 1 PC65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
Great info. Thanks!
This is a project to convert an old Dell PC to a machine to rip and play SACD and DVD-A multichannel files in my HT. I've read a couple threads that tell how to do it and I thought I'd dedicate some time and (very) little money to see if I could do it. I'm basically adding an HDMI output card to the pieces I already have, downloading some free SW and giving it a whirl.
Might work, probably won't :-)My 7.4.4 DIY 4k Home Theater:
HD-A35 HD DVD
You can also legally download a windows install file as it's the licence that's protected. I did this with my wife's PC and it worked just like an OEM disc.
Hi Chad,
Thanks for the disc! Got it yesterday.
Please let me know if I can help you out sometime.My 7.4.4 DIY 4k Home Theater:
HD-A35 HD DVD
