need r30 binding post
jumby181
one of the posts on my pair of r30's has broken. need the entire binding post assembly with the + and - posts that
screws onto the speaker cabinet. does anyone know the part number to order one?
Post edited by jumby181 on
Try CALLING Polk Customer Service. Otherwise, Parts Express sells all kinds of binding posts.Political Correctness'.........defined
President of Club Polk -
tried that once and somehow could not get them to understand what i needed. they sent me the female threaded
part of the binding post. that is why i am looking for a part number so i can just call and give them that -
From what I understand, Polk won't sell just the binding post, only the complete crossover assembly. At least that was my experience with my R50s. That said, I found a near-exact replacement at All Electronics:
http://www.allelectronics.com/make-a-store/item/BP-B/BANANA-JACK-BINDING-POST-BLACK/1.html
http://www.allelectronics.com/make-a-store/item/BP-R/BANANA-JACK-BINDING-POST-RED/1.html
Assuming the R50's have the same jacks, you should be good to go. I know they fit the R300, T15 and R15 (except the originals are not gold plated), so they will likely work for you as well. Good luck! -
thanks!!
