Monitor Audio Silver I7 worth 300 bucks?
EndersShadow
Title says it all. I have a pair local to me that are working and in good condition. He's willing to sell for 300 for the pair.
How do they compare to my LSi 15's for a straight 2 channel system?
Post edited by EndersShadow on
Silly question. You know the answer is to go listen. :razz:
But why tempt myself if its known it wont be worth it lol....
Specifically because more than likely they would be bought to flip."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
I modified a set of crossovers one time...
The tweeter is constructed so poorly it is not even funny. The entire structure is plastic, has a neo magnet and a cheap metal grill over the dome... The only reason I know it is cheaply constructed is the owner sent me the tweeter to try to fix because the tab broke off when he unplugged it...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
