Pair of class D amplifiers
zingo
I have a pair of these class D amplifiers that I used to power Carver ALIIIs and my father-in-laws LSi15 speakers. These amps are awesome with great sound quality and tons of power, however they are not a great match to my corner horn speakers, and I want more tubes... They rate at 220wpc at 8 ohms and 440wpc at 4 ohms, and excel at powering low impedance and hard to drive speakers. If you are considering any type of pro-amp for home use, these are a much better option, and a fairly low cost option for some high power. The amps have gain controls for each channel, so the volume can be set to match the rest of the system, or for use in bi-amping.
I'll let them go for $400 each shipped, or $700 for the pair shipped CONUS. They will come in original boxes with original foam packing to keep them safe.
Post edited by zingo on
GLWTS!!!
Those amps look ridiculously good!!!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Thanks. They sound fantastic with almost all speakers I've tested them on. Even my old Klipsch Fortes sounded good with them; it's just the corner horns really need tubes to sound their best.
They look small, which is good. I know these are class-d so power efficiency would be their advantage. I just spent a lot of money for some other gear, so I won't be able to pull the trigger on these, but is sounds like a good deal. BTW., what is the company that made these units? I couldn't find it anywhere. I have noticed made in USA.Music Room:
Paradigm Signature S8
Paradigm Signature C5
Paradigm Signature S2
Receiver - Onkyo tx-nr809
Amplifier - Adcom 5802
Office system:
Fronts - Polk RTI A7 (Trey Mod)
Center - Polk CSI A6 (Trey Mod)
Rears - Polk FXI A6
Sub - BIC F12
Receiver - SONY STR-DG1000
Amp - Carver TFM-35 -
The company is called "Class D Audio""....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Hey Zingo, just out of curiosity did you try them with a tube preamp ever?Review Site_ (((AudioPursuit)))
Former Staff Member TONEAudio
2 Ch. System
Cable/Wires: Cardas, AudioArt, Shunyata Venom 3 -
Double the rating into 4ohms......impressive....GLWTS.....peter -
Yes and they did very well paired with tubes. Still not enough tubes for the corner horns, but a great combo with every other speaker I used. -
Very nice amps.
I run a DIY from Class-D off a battery with a Dodd Tube Buffer and it sounds great! GLWSHT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
2 APC H-15s and a Panamax 5400 for good measure
Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers -
One amp is off the market and in my system. I'm now having it run the woofers on my corner horns, and it sounds fantastic. Nothing better than tubes feeding the high and mid horns and 440wpc feeding the 4 ohm horn loaded woofers. :cool:
How about John's amps feeding your woofers lol.... I believe thats better :biggrin::razz:"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Doubt it."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Agreed. SS for bass has a certain punch and snap that I haven't found with tubes, as much as I love them. Plus, these class D amps do a fantastic job powering low impedance (and/or low sensitivity) and controlling the woofer well.
What does GLWTS mean?EndersShadow wrote: »GLWTS!!!Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
"Get Lost With The Sound"
It's a compliment to these amplifiers.
Really though, it means "good luck with the sale", and there are probably better places than a sale thread to ask that question. -
Good luck with the sale.
Monster AVL-300, HTS-2500 MKII -
The amp sounds great in my system bi-amping with tubes. The other amp is still available.
PM sent. Very interested. Hard to belive an amp this cheap can sound that good though.
A link to some killer tubes. These will get the job done for sure.:cool:
http://app.audiogon.com/listings/carver-cherry-180-200wpc-tube-amps--4The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
nooshinjohn wrote: »A link to some killer tubes. These will get the job done for sure.:cool:
How's that for an effed up post in someone's for sale thread?Wristwatch--->Crisco -
Especially with that garbage."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I believe that his post was a link back to the previous comment that John's tube amps would drive the woofers better. No hard feelings between me and John. -
It is a class D amp, so it does sound different than a conventional A/B. Having talked to Tom the owner of Class D Audio, one of his design goals was to make an amp that was inexpensive enough that people would take a chance on it and try out a new design and newer technology. Everyone I have let demo the amp has liked the sound, but don't expect it to sound like a 250wpc A/B amp; for better and worse. -
While those amps do image well and have a tone I can see most enjoying, they still don't have the woofer control of a good class D(topology or brand) amp.I believe that his post was a link back to the previous comment that John's tube amps would drive the woofers better. No hard feelings between me and John."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Completely agree as any price, let alone $5500 for the pair. I'm not against expensive audio equipment as I don't have any where to talk with these speakers, but spending the wrong money is the wrong place is a waste of funds.
Class D technology is very interesting in that it offers sound that one do not get from the conventional class a/b. Worth the trip.Abbas Tube USB-SPDIF Converter with tube clocksAbbas V2 SE Tube DACAltmann Attraction DACNon-Pre passive preampYamaha M2 AmplifierDIY TPA3255 Mono Amps6L6 Williamson amplifier42 SET amp6V6 SET ampMcIntosh XRT18 speakersApogee Centaur MinorPioneer PAX A30 speakers
