TSI100/200i question
do these speakers come with a wall mount bracket already affixed to the back, or is it something that is done aftermarket by the consumer?
Main L/R= RT800I
center: CS400I
surrounds: FX500i
surround back (center): CS245i
sub= psw450
front presence : RT25i
Current receiver : Yamaha RX-V3000 (all above equipment purchased in 2000) 6.1 +Front presence
I'm upgrading to 11.2, surround back will be removed...
new surround back: TSI200
new back presence: TSI100
new sub: PSW125
New Receiver: Yamaha RX-A3010
7.1 (11.2)...
center: CS400I
surrounds: FX500i
sub= psw450
new sub: PSW125
7.1 (11.2)...
Post edited by billmich on
TSI100 do (metal keyhole brackets), but TSI200 don't.
as I read your answer...the 100's come with the keyhole brackets pre-installed
the 200 come with them, but I have to install them myself...
correct?Main L/R= RT800I
center: CS400I
surrounds: FX500i
sub= psw450
new sub: PSW125
7.1 (11.2)... -
No that's not right. The 100s have them pre-installed. The 200s, due to their size, do NOT come with anything other than themselves, if you want to wall mount them you need to buy the hardware and do it your self.
Hope that helps.
thank you for the clarification, is this hardware that is purchased from Polk, or can you recommend a source for cheap (but sturdy) brackets so I can simply hang them on a wall...Main L/R= RT800I
center: CS400I
surrounds: FX500i
sub= psw450
new sub: PSW125
7.1 (11.2)... -
Anyone have suggestions of a place to purchase a mount for the tsi200?
Basically all I am lMain L/R= RT800I
center: CS400I
surrounds: FX500i
sub= psw450
new sub: PSW125
7.1 (11.2)... -
Am looking to do is put a screw in a wall and hang this speaker.. Just like the 100's have a keyhole bracket mount
Thank you
BillMain L/R= RT800I
center: CS400I
surrounds: FX500i
sub= psw450
new sub: PSW125
7.1 (11.2)... -
Isn't the TSI 200 a little large to just rely on a single screw in the wall to hold it up? I sure would not mount it like that. If these TSI's are going to be used for surrounds, then why not use TSI 100's all around the room and use the built in key slot? They're smaller and you'll still get plenty of sound and it'll put less strain on your receiver. TSI 100's for surround duty is more logical to me.
maybe I should do that. I was thinking of using the 200's as my surrounds BACK speakers, and the 100's as rear presence speakers (yamaha receiver)
maybe i should forget about the 200's and just get 2 pair of 100's
any thoughts?Main L/R= RT800I
center: CS400I
surrounds: FX500i
sub= psw450
new sub: PSW125
7.1 (11.2)... -
It's pretty much up to you. There are mounts commercially available that can handle the almost 20 lbs of the 200s weight. It's just more of a hassle to drill, find the studs, place them and so on. But it can work and people here have done it.
Here's an old thread with just such mounts (I'm sure they're gone by now):
http://www.polkaudio.com/forums/showthread.php?132086-Wall-Mounts-(Pair)&highlight=M-40+wall+mounts
Amazon: Pinpoint AM-40 B should do the trick.
If you're still interested in mounting the TSi 200's, why not just get 2 little shelves to put on the wall to sit the speakers on? This way it'd at least be more sturdy than just 1 screw. Just get 2 L brackets and a small shelf. Of course, make sure to find a good spot on the wall, too.Current setup: Harman Kardon HKTS 30BQ
Next setup: Polk RTI A7's
Polk CSi A6
HSU VTF-2 MK4 12" SUB
Undecided on surround -
Silverfang2340 wrote: »If you're still interested in mounting the TSi 200's, why not just get 2 little shelves to put on the wall to sit the speakers on? This way it'd at least be more sturdy than just 1 screw. Just get 2 L brackets and a small shelf. Of course, make sure to find a good spot on the wall, too.
That would not be a little shelf. :razz:AVR-Onkyo TX-NR808
Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
Sub-Velodyne SPL-1000R -
Haha, well, you know. At least a wood thick enough, it'd have to have longer in depth than width, they certainly have some weight to them. My brother just got these speakers about a week ago, they're great bookshelf speakers, I'm impressed.
Not sure what type of brackets these are, but if you can find out, here's a suggestion: http://www.polkaudio.com/forums/showthread.php?106641-TSi200-vs-TSi400Current setup: Harman Kardon HKTS 30BQ
Polk CSi A6
Silverfang, link didn't workMain L/R= RT800I
center: CS400I
surrounds: FX500i
sub= psw450
new sub: PSW125
7.1 (11.2)... -
Weird, that link is to a thread on the Polk forums.
Anyway, here is a picture of what the guy did in the thread, he drilled two holes into the back of the TSi 200:Current setup: Harman Kardon HKTS 30BQ
Polk CSi A6
Hoping for a mount that won't set me back $60+ shipping...
Anything good for half that?Main L/R= RT800I
center: CS400I
surrounds: FX500i
sub= psw450
new sub: PSW125
7.1 (11.2)... -
Well, I found the ones posted in the picture above: http://www.amazon.com/Pinpoint-Universal-Bookshelf-Speaker-Mount/dp/B0016KJ9XW/ref=sr_1_45?s=electronics&ie=UTF8&qid=1342554989&sr=1-45&keywords=wall+mount+speakers
They're $30 a piece it seems, but at least you saw that picture, knowing it will hold the speaker securely.
Here's another just for reference:Current setup: Harman Kardon HKTS 30BQ
Polk CSi A6
30/pair, or 30X2=60?Main L/R= RT800I
center: CS400I
surrounds: FX500i
sub= psw450
new sub: PSW125
7.1 (11.2)... -
It seems they are $30 a piece, well worth it I'd say, especially considering they support up to 20lbs. Here's more info on their site if you're interested: http://www.pinpointmounts.com/am10.htmlCurrent setup: Harman Kardon HKTS 30BQ
Polk CSi A6
actually, it looks like it's 30 for 2 mounts (1 pair)
the online polk PDF of the manual doesnt list what the weight of the 200's are
any idea of how much each speaker weighs?Main L/R= RT800I
center: CS400I
surrounds: FX500i
sub= psw450
new sub: PSW125
7.1 (11.2)... -
I'd assume it would be listed in the product description if it came in a pair. Order 2, then send one back if they send 2 pairs, or order one and find out.
Also, I just weighed one of the speakers, reading at about 16.4lbs.Current setup: Harman Kardon HKTS 30BQ
Polk CSi A6
Sounds about right. Polk page says 17 lbs. I think I mentioned that in another post above?
http://www.polkaudio.com/products/tsi200
cnh
my apologies if I didn't see it above, getting a little tired here tonight.
and I also scoured the above link and didn't see anything about 17 pounds, but I will more than take your word for it
thank you again very much for the information
center: CS400I
surrounds: FX500i
sub= psw450
new sub: PSW125
7.1 (11.2)... -
You must be tired, here it is from the link.
Dimensions
Cabinet Dimensions
Height 15 7/16" (39.21cm)
Width 8" (20.32cm)
Depth 11 3/4" (29.84cm)
Product Weight (each) 17.00 pounds
