TSI100/200i question
billmich
billmich Posts: 19
edited July 2012 in Speakers
do these speakers come with a wall mount bracket already affixed to the back, or is it something that is done aftermarket by the consumer?
Main L/R= RT800I
center: CS400I
surrounds: FX500i
surround back (center): CS245i
sub= psw450
front presence : RT25i
Current receiver : Yamaha RX-V3000 (all above equipment purchased in 2000) 6.1 +Front presence
I'm upgrading to 11.2, surround back will be removed...
new surround back: TSI200
new back presence: TSI100
new sub: PSW125
New Receiver: Yamaha RX-A3010
7.1 (11.2)...
Post edited by billmich on
  • VSchneider
    VSchneider Posts: 443
    edited July 2012
    TSI100 do (metal keyhole brackets), but TSI200 don't.
  • billmich
    billmich Posts: 19
    edited July 2012
    as I read your answer...the 100's come with the keyhole brackets pre-installed
    the 200 come with them, but I have to install them myself...
    correct?
    Main L/R= RT800I
    center: CS400I
    surrounds: FX500i
    sub= psw450
    new sub: PSW125
    7.1 (11.2)...
    edited July 2012
    No that's not right. The 100s have them pre-installed. The 200s, due to their size, do NOT come with anything other than themselves, if you want to wall mount them you need to buy the hardware and do it your self.
    Hope that helps.
    cnh
  • billmich
    billmich Posts: 19
    edited July 2012
    thank you for the clarification, is this hardware that is purchased from Polk, or can you recommend a source for cheap (but sturdy) brackets so I can simply hang them on a wall...
    Main L/R= RT800I
    center: CS400I
    surrounds: FX500i
    sub= psw450
    new sub: PSW125
    7.1 (11.2)...
  • billmich
    billmich Posts: 19
    edited July 2012
    Anyone have suggestions of a place to purchase a mount for the tsi200?
    Basically all I am l
    Main L/R= RT800I
    center: CS400I
    surrounds: FX500i
    sub= psw450
    new sub: PSW125
    7.1 (11.2)...
  • billmich
    billmich Posts: 19
    edited July 2012
    Am looking to do is put a screw in a wall and hang this speaker.. Just like the 100's have a keyhole bracket mount
    Thank you
    Bill
    Main L/R= RT800I
    center: CS400I
    surrounds: FX500i
    sub= psw450
    new sub: PSW125
    7.1 (11.2)...
  • rebuy
    rebuy Posts: 695
    edited July 2012
    Isn't the TSI 200 a little large to just rely on a single screw in the wall to hold it up? I sure would not mount it like that. If these TSI's are going to be used for surrounds, then why not use TSI 100's all around the room and use the built in key slot? They're smaller and you'll still get plenty of sound and it'll put less strain on your receiver. TSI 100's for surround duty is more logical to me.
  • billmich
    billmich Posts: 19
    edited July 2012
    maybe I should do that. I was thinking of using the 200's as my surrounds BACK speakers, and the 100's as rear presence speakers (yamaha receiver)
    maybe i should forget about the 200's and just get 2 pair of 100's
    any thoughts?
    Main L/R= RT800I
    center: CS400I
    surrounds: FX500i
    sub= psw450
    new sub: PSW125
    7.1 (11.2)...
    edited July 2012
    It's pretty much up to you. There are mounts commercially available that can handle the almost 20 lbs of the 200s weight. It's just more of a hassle to drill, find the studs, place them and so on. But it can work and people here have done it.
    Here's an old thread with just such mounts (I'm sure they're gone by now):
    http://www.polkaudio.com/forums/showthread.php?132086-Wall-Mounts-(Pair)&highlight=M-40+wall+mounts
    cnh
  • chumlie
    chumlie Posts: 8,658
    edited July 2012
    Amazon: Pinpoint AM-40 B should do the trick.
  • Silverfang2340
    Silverfang2340 Posts: 42
    edited July 2012
    If you're still interested in mounting the TSi 200's, why not just get 2 little shelves to put on the wall to sit the speakers on? This way it'd at least be more sturdy than just 1 screw. Just get 2 L brackets and a small shelf. Of course, make sure to find a good spot on the wall, too.
    Current setup: Harman Kardon HKTS 30BQ
    Next setup: Polk RTI A7's
    Polk CSi A6
    HSU VTF-2 MK4 12" SUB
    Undecided on surround
  • hertz9753
    hertz9753 Posts: 310
    edited July 2012
    That would not be a little shelf. :razz:
    AVR-Onkyo TX-NR808
    Front amp-Adcom GFA 555>Polk Audio LSi9's(Vr3 Castle Mods)
    Center amp-Adcom GFA 5400>Polk Audio LSi9 bi-wired(Vr3 Castle Mod)
    Surrounds-Polk Audio F/X500's<Onkyo TX-NR808
    Sub-Velodyne SPL-1000R
  • Silverfang2340
    edited July 2012
    Haha, well, you know. At least a wood thick enough, it'd have to have longer in depth than width, they certainly have some weight to them. My brother just got these speakers about a week ago, they're great bookshelf speakers, I'm impressed.
    Not sure what type of brackets these are, but if you can find out, here's a suggestion: http://www.polkaudio.com/forums/showthread.php?106641-TSi200-vs-TSi400
    Polk CSi A6
  • billmich
    billmich Posts: 19
    edited July 2012
    Silverfang, link didn't work
    Main L/R= RT800I
    center: CS400I
    surrounds: FX500i
    sub= psw450
    new sub: PSW125
    7.1 (11.2)...
  • Silverfang2340
    edited July 2012
    Weird, that link is to a thread on the Polk forums.
    Anyway, here is a picture of what the guy did in the thread, he drilled two holes into the back of the TSi 200:
    Polk CSi A6
  • billmich
    billmich Posts: 19
    edited July 2012
    chumlie wrote: »
    Hoping for a mount that won't set me back $60+ shipping...
    Anything good for half that?
    Main L/R= RT800I
    center: CS400I
    surrounds: FX500i
    sub= psw450
    new sub: PSW125
    7.1 (11.2)...
  • Silverfang2340
    edited July 2012
    Well, I found the ones posted in the picture above: http://www.amazon.com/Pinpoint-Universal-Bookshelf-Speaker-Mount/dp/B0016KJ9XW/ref=sr_1_45?s=electronics&ie=UTF8&qid=1342554989&sr=1-45&keywords=wall+mount+speakers
    They're $30 a piece it seems, but at least you saw that picture, knowing it will hold the speaker securely.
    Here's another just for reference:
    Polk CSi A6
  • billmich
    billmich Posts: 19
    edited July 2012
    30/pair, or 30X2=60?
    Main L/R= RT800I
    center: CS400I
    surrounds: FX500i
    sub= psw450
    new sub: PSW125
    7.1 (11.2)...
  • Silverfang2340
    edited July 2012
    It seems they are $30 a piece, well worth it I'd say, especially considering they support up to 20lbs. Here's more info on their site if you're interested: http://www.pinpointmounts.com/am10.html
    Polk CSi A6
  • billmich
    billmich Posts: 19
    edited July 2012
    actually, it looks like it's 30 for 2 mounts (1 pair)
    the online polk PDF of the manual doesnt list what the weight of the 200's are
    any idea of how much each speaker weighs?
    Main L/R= RT800I
    center: CS400I
    surrounds: FX500i
    sub= psw450
    new sub: PSW125
    7.1 (11.2)...
  • Silverfang2340
    edited July 2012
    billmich wrote: »
    I'd assume it would be listed in the product description if it came in a pair. Order 2, then send one back if they send 2 pairs, or order one and find out.
    Also, I just weighed one of the speakers, reading at about 16.4lbs.
    Polk CSi A6
    edited July 2012
    Sounds about right. Polk page says 17 lbs. I think I mentioned that in another post above?
    http://www.polkaudio.com/products/tsi200
    cnh
  • billmich
    billmich Posts: 19
    edited July 2012
    cnh wrote: »
    cnh
    my apologies if I didn't see it above, getting a little tired here tonight.
    and I also scoured the above link and didn't see anything about 17 pounds, but I will more than take your word for it
    thank you again very much for the information
    Bill
    Main L/R= RT800I
    center: CS400I
    surrounds: FX500i
    sub= psw450
    new sub: PSW125
    7.1 (11.2)...
    edited July 2012
    You must be tired, here it is from the link.
    Dimensions
    Cabinet Dimensions
    Height 15 7/16" (39.21cm)
    Width 8" (20.32cm)
    Depth 11 3/4" (29.84cm)
    Product Weight (each) 17.00 pounds
    cnh
