Good buy?
Jimbo18
Jimbo18 Posts: 2,349
edited July 2012 in Vintage Speakers
I have a CS245i that I added a pair of RT35i's to at suggestions from this board. I have just been using them in the bedroom in a 3.0 setup with a new low powered Pioneer AVR. I might switch back to my older Sony STR-DE845 though.
But I found a deal on a CS400 and a pair of RT55's on CL for $125. Will the CS400 go okay with the 55's as fronts and the 35's as rears if I move to a 5.0 setup? And will 80 or so watts be enough to drive all that. The Sony is around 100 w/c?
The room is fairly large but since it's a bedroom, I don't often get to crank it much. I mostly just use the setup for TV and some music.
Post edited by Jimbo18 on
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2012
    It will be fine, not a perfect match but close enough. The RT55's are arguably the best bookshelf speaker from Polk Audio. They alone are more than worth the $125.
    Main Surround -
  • Jimbo18
    edited July 2012
    nguyendot wrote: »
    Thanks. One of the covers has a tear in it, but other than that, they are supposed to be solid. I am picking them up this evening if all goes right (cuz you never know with CL).
  • Jimbo18
    edited July 2012
    DSkip wrote: »
    Unsure why it isn't a perfect match? Go get them Jim. For that price you could easily flip them.
    I can't afford the kind of equipment everyone on here lists, but I find myself working my way up the Polk ladder, so to speak. I started out with a CS150 center and a pair of old Monitor 2's (or something like that, the ident plates are gone), then I got the CS245i and the RT35i's and now should be getting those I listed above.
    Not sure what the next step is, speaker-wise, but I keep reading this board and getting ready. I probably need a serious AVR upgrade before getting anything larger.
  • nguyendot
    edited July 2012
    Apologies, the CS400 is a perfect match, I thought it was a generation newer.
    I still use a pair of RT55's as my main speakers. They are one of my favorites.
    Main Surround -
  • Jimbo18
    edited July 2012
    Well, I bought them. Haven't even heard them yet but they seem to be in good condition cosmetically except for the hole in the bottom of one cover, that I knew about beforehand. And on the back, I don't even know what it's called but one is missing the rubber that covers the rear port. I have no idea if that matters or not. If it does, is there a site where I can order one?
    They are RT55's, not the 55i's and the center is the CS400, not the CS400i. The seller said I was the first to contact him but he could have sold them several times over.
    Tony M Posts: 11,617
    edited July 2012
    Congrats
    Slowly but surely is the best way to go down this rabbit hole. That's how I've been doing it for 17 years strong now.
  • cincycat13
    cincycat13 Posts: 888
    edited July 2012
    Nice grab! and if you decide they aren't your style you should be able to get rid of them without much trouble. I paid $100 just for the cs400. used it both with some rt55s and some rt800s for a while. ironically with a sony str de845. let us know how you feel about them compared to your current set up...of course after I got my RT55s I felt they used the term bookshelf loosely...
  • dpowell
    dpowell Posts: 3,081
    edited July 2012
    That's a fantastic price! Great score.
  • Jimbo18
    edited July 2012
    Thanks for the comments, guys. I haven't hooked up the center channel yet, but listened to some Pink Floyd Dark Side of the Moon last night and they definitely fill the room better than the 35s did. I will have to try them out on some other stuff tonight but the bass is better for sure.
    They are hooked to a Pioneer VSX 821K which I got a few weeks ago (also off CL $125 nib) but I want to hear them with the old Sony also. Not sure the Sony is enough either, but they will benefit from some more power.
    The wife's away till Friday so I just have to practice explaining why it was too good to pass up.
