digital audio cable for SurroundBar Surround Sound 42"
FX1
FX1 Posts: 6
Just bought a used SurroundBar Black Surround Sound 42" in excellent condition. Were can I buy the digital audio cable to hook up the 5 speaker wire connectors on the back to my receiver.
thanks
Post edited by FX1 on
  • jimbo1421
    jimbo1421 Posts: 772
    edited July 2012
    Just to clarify, this is the model you bought, right?
    http://www.polkaudio.com/homeaudio/products/recent/surroundbar42/
    If so, you will need regular speaker cables to connect it, nothing digital at all about the signal. Polk included a 5 channel, 10 wire ribbon cable with this model and perhaps they still have them. Check with customer service.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    Surround: Monitor 10B
    PSW10 subwoofer
    Onkyo PR-SC886P Pre/Pro
    NAD T955 5 channel power amplifier
    Technics SL-1710 MK2 turntable
    Audio-Technica AT14Sa cartridge
    Parasound P3 pre-amp
    Oppo BDP-103 Blu-Ray
    2014 MacBook Pro 2.8 GHz
    2.0 Office System:
    Monitor 10A (Peerless)
    Outlaw 1050 receiver
    Parasound HCA-1000A power amp
    MacPro
  • FX1
    FX1 Posts: 6
    edited July 2012
    Thanks Jim was hoping some one had a part number. I asked Polk support but nothing yet. I can hook it up but would like to use one cable with 10 wires.
    Thanks for the help.
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited July 2012
    Hello FX1,
    I believe the part number is RE5051-1 10 conductor 15' long cable, the Club Polk price should be $24.00. Give Polk's CS a call at 1-800-377-7655 to order.
    Cheers, Ken
  • jimbo1421
    edited July 2012
    It's color coded, too.
    If you cut it to length, it is a good idea to tin the bare wire with solder. I didn't on mine years ago and sheared off the wire when I tightened down the nuts. There were little shreds of wire all over the terminals which had to be cleaned up to prevent a shorting hazard.
    Jim
    5.1 System:
    TCL R613 55" 4K
    Front: SRS-3.1TL
    Center: CS400i
    PSW10 subwoofer
    2.0 Office System:
    MacPro
  • FX1
    FX1 Posts: 6
    edited July 2012
    Ken
    Much appreciate your quick reply. Can not believe it's 15 feet, first read though it was inches. To short and too long, lol. Will call tomorrow, tried looking up the RE5051-1 part number on-line but nothing.
    Aso Jim thanks for the suggestion, sure will do that. I have to hookup two set's of wires to the amp terminal, as I also have the Polk audio F/X Wireless Surround Sound. Would it be best to solder two wires together?
    Thanks to both of you made my day.
  • [Deleted User]
    edited July 2012
    No problem, the original cable was 25' long!
  • FX1
    FX1 Posts: 6
    edited July 2012
    Ken
    Can I buy on-line or do I have to call?
  • [Deleted User]
    edited July 2012
    Calling is the only way, I believe. Polk has considered online ordering, but they have so many various parts and are concerned that owners wouldn't order the correct ones.
  • FX1
    FX1 Posts: 6
    edited July 2012
    Ken
    Thanks for your suggestion, ordered today,great service. Really impressed with customer service and this forum.
    Much apprecated.
