digital audio cable for SurroundBar Surround Sound 42"
FX1
Just bought a used SurroundBar Black Surround Sound 42" in excellent condition. Were can I buy the digital audio cable to hook up the 5 speaker wire connectors on the back to my receiver.
thanks
thanks
Post edited by FX1 on
Just to clarify, this is the model you bought, right?
http://www.polkaudio.com/homeaudio/products/recent/surroundbar42/
If so, you will need regular speaker cables to connect it, nothing digital at all about the signal. Polk included a 5 channel, 10 wire ribbon cable with this model and perhaps they still have them. Check with customer service.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro -
Thanks Jim was hoping some one had a part number. I asked Polk support but nothing yet. I can hook it up but would like to use one cable with 10 wires.
Thanks for the help. -
Hello FX1,
I believe the part number is RE5051-1 10 conductor 15' long cable, the Club Polk price should be $24.00. Give Polk's CS a call at 1-800-377-7655 to order.
Cheers, Ken -
It's color coded, too.
If you cut it to length, it is a good idea to tin the bare wire with solder. I didn't on mine years ago and sheared off the wire when I tightened down the nuts. There were little shreds of wire all over the terminals which had to be cleaned up to prevent a shorting hazard.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
Ken
Much appreciate your quick reply. Can not believe it's 15 feet, first read though it was inches. To short and too long, lol. Will call tomorrow, tried looking up the RE5051-1 part number on-line but nothing.
Aso Jim thanks for the suggestion, sure will do that. I have to hookup two set's of wires to the amp terminal, as I also have the Polk audio F/X Wireless Surround Sound. Would it be best to solder two wires together?
Thanks to both of you made my day.
Tom -
No problem, the original cable was 25' long!
Ken
Can I buy on-line or do I have to call? -
Calling is the only way, I believe. Polk has considered online ordering, but they have so many various parts and are concerned that owners wouldn't order the correct ones.
Ken
Thanks for your suggestion, ordered today,great service. Really impressed with customer service and this forum.
Much apprecated.
