Looking for carver al-iii non + loudspeaker ribbons
sam046
I am looking for the 48" ribbons(2 ea) for the subject Carver Loudspeakers and preferably some that have had the ribbons rebuilt. I have a pair of these speaker in mint condition and I had the ribbons rebuilt recently by James Sauter. The problem is, that the speakers were intermittently cutting out while playing and I found that the circuit board that makes contact with the ribbon traces were not making good contact and the screws were not very tight, so I snugged them a little to put more pressure on the contacts and apparently tightened one speaker too much and the circuit board cut through the aluminum traces and pretty much rendered it useless. I have been an electronic technician for 30+ years and if it were anything but aluminum I could repair it like new, but instead I have not found anyway to repair these traces. I tried a conductive ink, but the resistance was too high after it dried. I could get these rebuilt again, but James Sauter is the hardest person in the world to get hold of and very rarely answers my emails. He does beautiful work and I highly recommend his repair, but it's so frustrating trying to get hold of him, not to mention that I hate to admit how bad that I screwed this up. Thanks in advance!
Post edited by sam046 on
Got a roll of Reynold's Wrap in the kitchen drawer and some gelatin adhesive ? Experiment !!!
I've experimented to the point that there is very little material to work with and believe me, the Reynold's wrap was among the first, since it was aluminum material. I think I may have found a solution. I'll let you know if it works! What makes it even harder is the fact that the area you have to work in is hard to access.
Have you tried emailing Bob Carver? I don't know if his shop still fixes those, but he might be able to make a recommendation anyway.
Yes I have! James Sauter that I mentioned in the original post, is associated with Bob Carver and he is the only one in the world that repairs these. I just spend $800.00 to have him rebuild both of my ribbons and they never sounded better until I screwed it up and believe me, I'm beating myself up pretty bad for this. I've got one more thing to try and if that doesn't work, I guess I'll have to bite the bullet and get him to repair the ribbon. Thanks for the suggestion!
Steve -
Why cut corners? Get it fixed right!
I couldn't agree more. I'm a serious audiophile and a perfectionist and I've already talked to the guy that rebuilt them recently and he told me that he would rebuild it again. I guess another $400.00 is not too bad of a price to pay to ease my mind and to know that it will be like new again. Thanks for the reply!
