Onkyo Receiver Shut-off while Speaker Caliberation
SKUMAR1973
SKUMAR1973 Posts: 1
edited July 2012 in Troubleshooting
I have RM6750 speaker sets for my Home Theater.Over six months there was no issue , recently i found that when i increase the volumn in the receiver( above 40), system automatically shut-off.I started doing my trouble shooting .While i was caliberating the speakers, I had increased the volumn with one speaker at a time and found that receiver getting shutt-off when one of the surr-speaker and center chaneel speaker hooked up with receiver
Any idea why it is happening? inputs/suggestions are appreciated
SK
Post edited by SKUMAR1973 on
    F1nut Posts: 52,147
    edited July 2012
    Just a guess, but I'd say your AVR has issues with the amps driving those channels.
    If you're using bare wire connections, check for stands of wire touching other wires/connections.
