Thrift Store Find - B&W DM601
skrol
skrol Posts: 3,437
edited July 2012 in Speakers
Popped into a little thrift store not too far from where I work the other day and found a bunch of old stereo equipment. Most was low end stuff not worth having. Some was rather unique like a Pioneer reverb processor.
I did pick up a pair of B&W DM601 in so-so condition that I got for $40. One is missing a shorting bar to connect the tweeter woofer and the other is missing a dust cap from the woofer. Both function, cabinets and grills look good. Any opinions on these speakers?
Stan
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
  • onebadchad
    onebadchad Posts: 364
    edited July 2012
    Gotta love the thrift store scores!
    Hello Kitty am/fm CD player
  • litezoner
    litezoner Posts: 13
    edited July 2012
    C/P Description
    The Bowers & Wilkins DM601 Speaker is a bookshelf speaker system with a signal-to-noise ratio of 88 dB. This Bowers & Wilkins speaker has a double skinned baffle construction and uses extra internal bracing for reduced coloration and clearer sound. This Bowers & Wilkins bookshelf speaker has a frequency response ranging from 60 Hz to 22 kHz. This Bowers & Wilkins speaker has an impedance rating of 8 ohms, and a crossover point at 4 kHz. The Bowers & Wilkins DM601 Speaker uses a 6.5? woven Kevlar cone bass driver and a 1? Nautilus tube-loaded metal dome tweeter to ensure that both highs and lows are reproduced without any distortion.
    Product Identifiers
    Brand B&W
    Model DM601
    Key Features
    Speaker Type Main / Stereo
    Mounting Bookshelf
    Construction 2-Way
    Technical Details
    Peak Power Handling 200 watt
    Frequency Reponse 70 Hz - 20 kHz
    Impedance 8 ohm
    Sensitivity 88 dB
    Design
    Available Colors Black
    Dimension
    Width 8 in.
    Depth 9.6 in.
    Height 14 in.
  • leftwinger57
    leftwinger57 Posts: 2,917
    edited July 2012
    That's pretty damn good for $40.My bookies were ten but yours are definately of a higher quality.The jumper is a nothing ,and I guess you get a matching dust cap fairly eaisly.Put them to use.
  • skrol
    skrol Posts: 3,437
    edited July 2012
    B&W lists the bi-wire link for $1.81. I am not sure where to look for the dust cap as B&W doesn't list it. Parts Express sell some but it won't match. I will probably call B&W. Any other suggestions?
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
