Thrift Store Find - B&W DM601
Popped into a little thrift store not too far from where I work the other day and found a bunch of old stereo equipment. Most was low end stuff not worth having. Some was rather unique like a Pioneer reverb processor.
I did pick up a pair of B&W DM601 in so-so condition that I got for $40. One is missing a shorting bar to connect the tweeter woofer and the other is missing a dust cap from the woofer. Both function, cabinets and grills look good. Any opinions on these speakers?
Stan
Main 2ch:
HT:
Other stuff:
Main 2ch:
HT:
Other stuff:
Post edited by skrol on
Gotta love the thrift store scores!Hello Kitty am/fm CD player
C/P Description
The Bowers & Wilkins DM601 Speaker is a bookshelf speaker system with a signal-to-noise ratio of 88 dB. This Bowers & Wilkins speaker has a double skinned baffle construction and uses extra internal bracing for reduced coloration and clearer sound. This Bowers & Wilkins bookshelf speaker has a frequency response ranging from 60 Hz to 22 kHz. This Bowers & Wilkins speaker has an impedance rating of 8 ohms, and a crossover point at 4 kHz. The Bowers & Wilkins DM601 Speaker uses a 6.5? woven Kevlar cone bass driver and a 1? Nautilus tube-loaded metal dome tweeter to ensure that both highs and lows are reproduced without any distortion.
Product Identifiers
Brand B&W
Model DM601
Key Features
Speaker Type Main / Stereo
Mounting Bookshelf
Construction 2-Way
Technical Details
Peak Power Handling 200 watt
Frequency Reponse 70 Hz - 20 kHz
Impedance 8 ohm
Sensitivity 88 dB
Design
Available Colors Black
Dimension
Width 8 in.
Depth 9.6 in.
Height 14 in. -
That's pretty damn good for $40.My bookies were ten but yours are definately of a higher quality.The jumper is a nothing ,and I guess you get a matching dust cap fairly eaisly.Put them to use.2chl- Adcom GFA- 555-Onkyo P-3150v pre/amp- JVC-QL-A200 tt- Denon 1940 ci cdp- Adcom GFS-6 -Modded '87 SDA 2Bs - Dynamat Ext.- BH-5- X-Overs VR-3, RDO-194 tweeters, Larry's Rings, Speakon/Neutrik I/C- Cherry stain tops Advent Maestros,Ohm model E
B&W lists the bi-wire link for $1.81. I am not sure where to look for the dust cap as B&W doesn't list it. Parts Express sell some but it won't match. I will probably call B&W. Any other suggestions?
StanStan
Main 2ch:
HT:
Other stuff:
