1/2 " Mye Sound Brass Spikes and Pads
CCNJ
CCNJ Posts: 384
edited July 2012 in For Sale (FS) Classifieds
I have a brand new set of 8 Mye Sound 1/2" UNC Brass Spikes and Floor Pads. I bought them new from Grant last year for a project that never materialized. Price is $120 plus $10 flat shipping to continental US. This is a 20% savings. I will also throw in a set of 8 T-Nuts.
Here is a link to the Mye Sound website if you need to see pictures and description. Spikes (points) are 2nd from right.
http://www.myesound.com/Points_n_pads.html
Chris
Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4
Post edited by CCNJ on
  • c0redumpt
    c0redumpt Posts: 35
    edited July 2012
    Would these fit okay re thread on 1.2 TL's by chance??
    EndersShadow Posts: 17,707
    edited July 2012
    c0redumpt wrote: »
    I believe they will. These were the go to standard until they stopped making them iirc.
  • c0redumpt
    c0redumpt Posts: 35
    edited July 2012
    If these definitely are the ones for 1.2 TL's then PM coming your way :)
    Actually just did some research and from what I've read the thread pattern for SDA speakers including the 1.2 TL is 1/4"-20. Which from the topic these are not ... doh!
    F1nut Posts: 51,814
    edited July 2012
    c0redumpt wrote: »
    You would have to remove the factory installed 1/4-20 T-nuts and install the 1/2"UNC T-nuts. A pretty easy job really.
    Mye Sound spikes are excellent, it's a damn shame he no longer sells 1/4-20 size.
  • c0redumpt
    c0redumpt Posts: 35
    edited July 2012
    Hmm that sounds like something that would work nicely then :) Thanks F1
  • CCNJ
    CCNJ Posts: 384
    edited July 2012
    Still available - Shipping to continental US only
  • CCNJ
    CCNJ Posts: 384
    edited July 2012
    bump
