Aluminum slab under DF SW?
KiTsuNe
KiTsuNe Posts: 74
I have a carpeted room and read that many people have put tile or granite to get rid of the muddy bass. Would a 1/2" thick piece of aluminum or polycarbonate under the sub would work? I have access to these two materials for free but if it would sound better with plywood or something else I will be willing to spend the money to make something from home depot.
HT: M5510-Prox2/PN51E550/NR708/M282(3)/RTi A7/CSi A6/FXi A6/DSWPro660x2/PS3/HTPC
Office: Belkin PF60/PN43E450/Marantz 1501/PSB 400/Image C4/WD Live TV
2-Channel: Yamaha C4/M4(2)/DQ-10's/DQ-1w(2)/SBT/Pioneer R2Rl/Technics SL-7/AR EB101
Desk: QSC RMX850/Behringer B2030P
Post edited by KiTsuNe on
    VR3 Posts: 29,554
    edited June 2012
    You will find most people are using 1-2" thick pieces under their sub... 1/2" would rattle just as much as your floor..
    2'x2'x2" concrete pavers works great - 8 bucks!
  • KiTsuNe
    KiTsuNe Posts: 74
    edited June 2012
    Thanks! i'll pick one up and give it a go.
