What is the input impedance of a Polk Audio PSW505 Subwoofer
Is it high enough so that I can hook up two subs from one LFE pre-out on my receiver using a RCA Y-splitter without causing the signal to be too quiet or to clip?
Post edited by WagBoss on
It doesn't matter how high it is. You can split pre-out signal without any problems.I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs.
jeremymarcinko wrote: »But as in all things your perception is your reality. -
1.21 gigawatts
AsSiMiLaTeD wrote: »1.21 gigawatts
Da-n you....my flux capacitor only gets 1.20 gigawatts,now I've got to upgrade:eek:.....O....the humanity! -
You should be fine as long as you aren't running two 50ft runs between the AVR and the subs. Try to keep the connection as short as possible.
