Power Cable Questions
bobsauto49
bobsauto49 Posts: 973
I'm looking to upgrade my PC on my B&K,and my Onkyo to Pangea. Question i have is their website says AC-9 for Amps,and AC-14 for for sources,and preamps. My Onkyo acts as my preamp,but also runs 3 channels. So,which cable is best? The AC-14 is about $20 cheaper,which isnt much,but i want the best cable for the purpose. Any suggestions?:idea:
"Everything I ever did in my life worthwhile I caught hell for"
Post edited by bobsauto49 on
  • grimmace19
    grimmace19 Posts: 1,429
    edited May 2012
    I think you would be just fine with the ac-14. Not to mention the added advantage that the 14 is somewhat flexible as to the 9 which is so thick it's hard to bend the way you need it.
  • BlueFox
    BlueFox Posts: 15,250
    edited May 2012
    First, you want the SE version of each cable. If you have the room get the AC-9SE. However, the 9 is a 7 gauge cable, and requires adequate room behind the gear in order to bend.
    I started with Pangea, and they made an audible improvement in my gear. However, now I am a Shunyata fan. For a starter cable I would go with the Shunyata Venom 3. It costs a couple dollars more than the Pangea, but is a better cable IMO.
    http://www.musicdirect.com/p-9670-shunyata-venom-3-power-cable.aspx
  • bobsauto49
    edited May 2012
    Thanx fellas! @Bluefox,I was hoping to spend $150 max for 2,which was why i was looking at the AC-9/AC-14,and hoping to hear a noticable difference in sound!
  • Ern Dog
    Ern Dog Posts: 2,237
    edited May 2012
    I currently use 2 AC-9's in my system and they do an excellent job. I tried the AC-14SE on my source and found that the AC-9 sounded better, so I sold the 14SE. Of course your mileage may vary from my results. I'd go with the AC-9's, but they are Huge and do ok (not great) with flexibility.
  • BlueFox
    edited June 2012
    Wow. Two dumba$$ spammers in a row. Back into your septic tank, you dung beetles.
