Help me Choose a new (used) AVR
bklynNupe
I?m looking for a new dvr. I?m thinking the biggest feature I want is room correction such as Audyssey and overall good sound.
Do I need hdmi if I?m connecting my cable and blu-ray directly to the t.v?
I?m not sure if I should really care about video upscaling?
I use external amps, should even bother with a receiver? I would say my budget is around $800 for something used. I?m currently using a Onkyo 806 and would like to try something new. Thanks.
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Rtia9 /csia6 / FXi A6
Samsung LN46A650
SVS PB-12-NSD sub
Audio Research SP-9 MKIII (GNSC mods)
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Audio Aero Prima CD player
Pro-Ject debut
Post edited by bklynNupe on
anyone?
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Samsung LN46A650
SVS PB-12-NSD sub
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Pro-Ject debut -
Onkyo TX-NR709. Done. Either new or refurbished from accessories4less.com."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Or if you want to get the most features for $800 the Onkyo TX-NR1009 is $847.
http://www.accessories4less.com/make-a-store/item/ONKTXNR1009/Onkyo-TX-NR1009-9.2-Channel-Network-A/V-Receiver/1.htmlAVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
I'll tell you what, if you want to try some of the refurbs on the site recommended above and don't want to go Onkyo since you've already been there. Look at the Marantz 600X (newest = highest number you can afford) or maybe the GREAT deal on that Denon AVR 4310 (little older but has what you need).
You "do not connect the TV and Blu-ray to the Onkyo"? Why not? You cannot get HD surround format decoding unless you run the HDMI audio through the Onkyo! So you might want to rethink that since this is the best blu-ray audio format!
The Denon and the Marantz will give you a little less forward sound and might tame those emotiva amps some, "warm" them up for music!
cnh
Sounds like good advice, I'll start doing my homework. Your also right regarding the Onkyo and emotiva being a little forward. I didn't realize this until I added my dedicated 2-channel rig. When I only had HT for music, I though it was the shizits. Now I know better. I will give the Marantz and Denon a look. Thanks.
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Samsung LN46A650
SVS PB-12-NSD sub
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Pro-Ject debut
