Polk Audio LSi9 Crossover Modification Thread
Excellent job on those LSi9 crossovers. I love the use of the all-thread to keep everything clean and orderly.
Thanks Rick!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
A cool budget Castle mod!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
The crossovers going into the recorded speakers...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sweet taters those look good!
Thanks! :-D- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Wish I could get my hands to move that fast
This is great. -
ESA caps! They finally fit!! :-D- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Looks nice. Those for a customer or for your personal evaluation?
Thank you sir!
These were for a customer!
We are constantly trying to fit nicer stuff on our Fortress stack! I think after seeing the 400v MR we may try sticking them on there every once and a while!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I am really liking the overall look now, I feel like "it" is "there"- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Those look great! I think I have finally figured a layout to work the ESA into my tweeter circuit and make it all fit through without making them even taller.
Thank you sir!
That is going to be a massive crossover...
Are you changing the 260uf with ESA as well? That has gotta be massive- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Are you changing the 260uf with ESA as well? That has gotta be massive"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
No...not doing the LF that way. Just going to do a bennic with an ESA by-bass similar to your pictures. I looked at DarkNight's mod where he did a replacement, but did not want to spend that kind of money at this time. And I still am not a fan of the LSiC so I grabbed some LSiM703/706c to try so not even sure why I am doing this, other than I had already started the process and it should be a fun project. Not looking forward to stuffing something into the LSiC space....that is small. I was leaning towards the LSiM due to the 8 ohm rating and an AVR configuration, but I am seeing some other threads questioning the 8 ohm AVR friendliness of the LSiM line. I have the Fortress 9's hooked up to a NAD 2600 and they sound great. Hope to get these 9's modded over the next 2 weeks and see how things go from there.
The ESA would definitely be external with the 260 - that would be probably 3"x3"x7" of just caps!
Make sure you post pics of the ESA mod, it will be nice for sure!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Whole lotta crossover for a little speaker
Gotta them VR3 mods....
I was listening to my SDA's today (stock xover) vs the VR3 LSIM 703's and they can hang.... The tweets in the 703's sound better than the SDA's but SDA's just push so much more air on the mid and bottom... I should probably get the xovers in the SDA's to you sometime soon tho... but they do sound very good even now.... I am going to check them to see if they were upgraded...
You da man!My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Thanks Mike!
Which sdas do you have?- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
sda srs 2.3 (not tl's)My New Year's resolution is 3840 × 2160
The gimpod mods are compatible but we can always go hardcore with the Monastery https://us.v-cdn.net/5021930/uploads/editor/fn/9mpa15v95s3x.jpg
https://us.v-cdn.net/5021930/uploads/editor/9b/w46w3o3sx5kl.jpg
https://us.v-cdn.net/5021930/uploads/editor/x1/nqud1ajpdt3r.jpg
https://us.v-cdn.net/5021930/uploads/editor/xg/6e4yvj93iotp.jpg- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Those are beautiful Tray!!!Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Thank you sir- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Trey! Its awesome things are going well! Dude those mods are sick! What wiring you using for those p2p connections?
Thanks man!
90% of the PTP connections are from component to component, infact - all of them are except for the +/- from the plate and from one side of the lead on the 1uf. Those wires are a generic stranded 16 awg OFC. The wires from the crossover to the drivers are Supra Classic.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Thank you:D- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Clarity Cap CSA/ESA
Mundorf Mox
Jantzen Inductors
Mundorf E-Cap
It was actually kind of cool to see how this build has evolved over time in this thread...
Post edited by VR3 on- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
thank you- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
