SDA 2B HF Inductor Measurements
VR3
VR3 Posts: 29,495
edited June 2012 in DIY, Mods & Tweaks
L1 - 2.66 MH, 1.35 ohms
L2 - 1.25 MH, .89 ohms
SDA Inductor (L3?) - 16.29 MH, 2.65 Ohms
Post edited by VR3 on
    VR3 Posts: 29,495
    edited June 2012
    I forgot one - will update in a sec, sorry
    VR3 Posts: 29,495
    edited June 2012
    Smallest Inductor - in high frequency circuit -
    .42 MH, .72 ohms
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited June 2012
    VR3 wrote: »
    .42 MH, .72 ohms
    I measured similar values for the stock inductors in my CRS+'s (same crossover as SDA 2B) prior to replacing them. A brief discussion of that mod is in figures 11-13 of this post. The prior CRS+ crossover modification is discussed in this thread.
    0.40 mH, 22 AWG
    > 0.416 mH, 0.71 ohms.
    1.25 mH, 20 AWG
    > 1.279 mH, 0.88 ohms.
    2.50 mH, 20 AWG
    > 2.470 mH, 1.27 ohms.
    16 mH, 18 AWG
    >16.300 mH, 2.66 ohms.
    VR3 Posts: 29,495
    edited June 2012
    Did you end up replacing them? If so, what did you find that was similar??
    The closest thing I have found ERSE makes but I don't think it would be worth replacing them with the ERSE inductors...
    VR3 Posts: 29,495
    edited June 2012
    NVM, I see you did replace them with the Jantzen inductors ---
    VR3 Posts: 29,495
    edited June 2012
    DK, where did you order those inductors from?
    Parts Express does not seem to stock some of the values....
    Thanks!
  • DarqueKnight
    edited June 2012
    The replacement Jantzen inductors (special ordered from Parts Express) had the following measurements:
    0.40 mH, 22 AWG
    > 0.413 mH, 0.64 ohms.
    1.25 mH, 20 AWG
    > 1.259 mH, 0.82 ohms.
    2.50 mH, 20 AWG
    > 2.509 mH, 1.34 ohms.
    Jantzen part numbers and prices were:
    0.40 mH, 22 AWG, Part No. 1489, $2.86.
    1.25 mH, 20 AWG, Part No. 1137, $5.63.
    2.50 mH, 20 AWG, Part No. 1695, $8.61.
    The 16 mH, 18 AWG SDA inductors in two or my CRS+ pairs were replaced with Northcreek 16 mH, 14 AWG, 1.3 ohm inductors, $114.30 each.
    The 16 mH SDA inductors in my third pair of CRS+'s was replaced with Solen 16 mH, 14 AWG, 0.945 ohm inductors, $67.68, part number S1416.0. The Solen inductors outperformed the Northcreeks and cost 40% less. The Solen inductors were ordered from Parts Connexion.
    VR3 Posts: 29,495
    edited June 2012
    How long did it take you to receive your inductors being a special order?
    Thanks!
  • DarqueKnight
    edited June 2012
    The Jantzen inductors took six weeks to arrive from Denmark. The standard special order delivery period for Jantzen parts is eight weeks. The Solen inductors took eight days to arrive from Canada.
