I'm confused on SDA 2b upgrade -
  • Schurkey
    Schurkey Posts: 2,122
    edited June 2012
    mc.ubba wrote: »
    Can anyone recommend the "perfect" amp for these.
    No such thing as "perfect". Must be able to drive moderately-low impedances. Must be common-ground.
    mc.ubba wrote: »
    What about a modest tube amp?
    Sure...if it meets the above criteria.
    mc.ubba wrote: »
    what would be the first thing I should do as a replacement/upgrade in the future.
    FIRST, fix any defects. Non-working drivers, incorrect wiring, Dacron stuffing sagged down to the passive radiator, cabinet air leaks,etc.
    After that, the sky is the limit. "I" would start with replacing every capacitor and resistor on the crossover boards.
    Some folks upgrade the wiring, the jacks, the inductors, etc. Some folks disable the SDA tweeter. Listen, decide, have fun!
  • bmbguy
    bmbguy Posts: 416
    edited June 2012
    F1nut Posts: 52,009
    edited June 2012
    I bundled 3 90uf for the SDA board which did nothing until I yanked the stock sda port and applied the bare steel wires to some 12 speaker wire and after plenty of juice i did get a little sda effect.
    Ok don't use them and don't get sonicaps and don't upgrade sda port.
    You and your speakers have issues.
  • mc.ubba
    mc.ubba Posts: 3
    edited June 2012
    Smallies wrote: »
    Ok don't use them and don't get sonicaps and don't upgrade sda port. Cape Cod Massachusetts here kiddos. My neighbors are over 100 feet away and it's 66 cool degrees in the dining room. Cheers!
    This confuses and baffles me! Thanks for all the answers and links everyone. They sound great as is but I guess I'll start with taking off the radiators and looking inside.
  • mc.ubba
    mc.ubba Posts: 3
    edited June 2012
    OH, and does anyone have any experience driving these with a low watt tube amp?
    Toolfan66 Posts: 18,189
    edited June 2012
    mc.ubba wrote: »
    Please ignore him as he knows not what he speaks. Plenty of good folks around here to help you out..
