Does Polk use Air Core Inductors...
dean/klipschead
...in their crossovers?
Dean
Quicksilver M-60 monoblocks - JM 200 Peach Linestage - Sony DVP-S9000ES - '03 modified Klipschorns
"I'm sure it's better than it sounds."-- Mark Twain, when asked what he thought about Wagner's music
Post edited by dean/klipschead on
The ones that I have see (800i and 3000 sat)use iron core.
Nope, not since the SDA line.Proud and loyal citizen of the Digital Domain and Solid State Country!
do you guys have an opinion about that
that is - is it necessarily a 'bad' thing?Dean
"I'm sure it's better than it sounds."-- Mark Twain, when asked what he thought about Wagner's music -
Air core inductors have lower distortion characteristics than iron core inducters, Their relatively high resistance can cause a problem if not used properly, iron core inductors are preferred because of their low resistance.
Thanks Hunter!Dean
Yea I agree with Hunter and would only add that the iron core aids in concentrating magnetic lines of flux and that is why it is eaiser to drive the speaker.
With air core, it takes greater amounts of current to reproduce the signal, but is less suspect to "noise" or interference that iron.
Joe
