can oppo bdp 93 be used as an external dac?
EDUBAG
EDUBAG Posts: 403
edited June 2012 in Electronics
hey guys,
just like the title says, if i have an external harddrive or usb flash memory with music or whatever device via usb. can the oppo be used as an external dac, if so, how good is it compared to stand alone cd player on the sam price range (500)?
i have the oppo dv980hd that i use for cd playing only and was wondering if the next step should be adding an external dac or a player like the oppo.
anybody knows how the bdp93 compares to the dv980hd?
thanks,
eduardo
HT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES
Post edited by EDUBAG on
  • BlueFox
    BlueFox Posts: 15,250
    edited June 2012
    I do not think the Oppo 93 has a digital input, so it cannot be used as a DAC. It can be used as a CD/SACD player, and is probably as good as similar priced DVD players that play CDs. The Oppo 95 has a great reputation as a CD player, but costs twice as much.
  • EDUBAG
    EDUBAG Posts: 403
    edited June 2012
    BlueFox wrote: »
    my dv980hd reads usb drives, and i beleive that the 93 does as well i just would like to know how good it is, the 980 i did not like at all as a dac. it is a pretty decent cd player but was wondering if i will gain more buying a 93 or a stand alone dac (same price range)
    HT:
    CSI3 CENTER
    PSW 125 SUB
    APPLE TV 160GB
    2 CHANNEL:
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited June 2012
    Yes, you can use the Oppo 93's internal DAC. Is this just for music or will you be using the video portion as well? If it's just for music I would try an external DAC to use with you current oppo.
  • BlueFox
    edited June 2012
    EDUBAG wrote: »
    If the 980 sounds better with CDs than it does with USB then the USB interface is the issue. If you are trying to kludge something with USB drives then maybe you can kludge the Oppo 93 to be a "DAC". However, your $500 is better spent by buying the new Cambridge-Audio DAC Magic Plus.
