Asus xonar to monitor 30
cac21ace
I was wondering can or how do i hook up my sound card to my speakers... i have been trying to research it but the more i read the more confused i get
Post edited by cac21ace on
You need an integrated amp or receiver. How much are you looking to spend?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
K it looks like im gonna go with an amp... but since im new to this i dont know how many watts im going to need for 2 pol audio monitor 30.. any suggestions
Watts are over rated.
You're going to use the analog out of your sound card, correct(RCA's)?
If so, something like this would sound nice: http://www.amazon.com/Cambridge-Audio-Integrated-Amplifier-Silver/dp/B003R2QHVY For a cheaper solution: http://www.amazon.com/Harman-Kardon-HK-3390-Receiver/dp/B00198BOAM/ref=sr_1_1?s=electronics&ie=UTF8&qid=1339605980&sr=1-1"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Yes im going to plug it into my RCA ....Can i go with something like this
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-380
or
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-383
Thank you for the replies back -
Either one of those would work too, but I don't know how they sound."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Go with the cambridge.I just might get it for a PC based sound system.
Nice find.SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
I'm using a Cambridge Azur 340A for my desktop setup. More than enough for me and sounds nice.
