DSLR Camera Suggestions
I saw the T4i; it's also going to be $500 more than the T3i. Though it is quite a bit more camera. I probably should have waited, but I'm not complaining. Well ok, maybe a little lol.
I was playing with the video allot today. Mainly to see the difference between 1080 30fps and 720 60fps. I can tell ya, 90% of the time it's going to be in 720 mode. It'll end up being used mostly for action stuff. And I always love seeing videos slowed down.
I'm all too familiar with expensive glass. Only one of my rifle scopes were under a grand, and that one was $400 sitting on top of my 22.
The deficiencies of the kit glass will eventually bug me, especially when I see what the better glass will do.
Gotcha. If you need the slow-mo, you need the slow-mo. Lots of nasty moire and artifacts at 720 but if that doesn't bother you, it'll do just fine. Btw, I'm not sure what platform you'll be editing video on, but Final Cut Pro X has an excellent little feature called 'optical flow' that makes 1080p 30fps look excellent in slow motion. -
I'll be using winbloze 7.
