Contemplating Something New
styx
styx Posts: 37
edited September 2012 in Electronics
Hey Gang,
I'm considering getting a new receiver for my music room. I love the Sansui G-7500 that's there now but am looking to try a new receiver with a remote, of which I'm looking @ Yamaha's new R-S700 and the Outlaw RR2150. It will be used in rotation with the G-7500 and a Kenwood KR-5030 and yes, I'm a "receiver guy".
I've read good reviews on both and they match up pretty well but would like to hear from those that have experience with either. I like the look of both (wish the R-S700 was available in silver) but lean more towards the art deco look of the RR2150. I also like the fact that both have tone controls and the R-S700 has a loudness control, which I use fequently. I doubt I could go wrong with either one but it never hurts to get opinions.
Thanks,
Styx
Condo: HK-3490, HK Bridge II, HK BTA-10 Polk TSx500T's
Post edited by styx on
  • erniejade
    erniejade Posts: 6,321
    edited June 2012
    I prefer the outlaw sound vs yamaha. The outlaw also has a MM and MC input for the phono and at the price point, i think it would basically just come down to preference. Both have sub out and i see the outlaw is switchable on the HZ on the back of the unit but, i don't know if the yamaha if you can select the freq.
    If your a phono user, having the MC and MM might come in handy.
    Other than that, spec wise they are both darn close. It would come down to what sound you prefer.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited June 2012
    I have not heard those two units, but I can tell you that I prefer the Outlaw house sound vs the Yamaha. With the Klipsch in the mix the Yamaha would be too bright for my tastes, the Outlaw should have a more neutral sound.
    That's my opinion on the general house sound of both companies, can't speak for the actual units in question directly.
    edited June 2012
    You gotta love the new Yamaha "retro" look! That said, the Outlaw (I'm pretty sure that is NO longer in production) is/was probably the best receiver in its price range! There are many reviews on line which claim it bests some integrateds?
    cnh
  • gdb
    gdb Posts: 6,012
    edited June 2012
    Won't be Stellar..........:razz:
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited June 2012
    Never hear either but the look of that RR2150 excites me
  • styx
    styx Posts: 37
    edited June 2012
    Thanks for the replies. I emailed Outlaw to see if the RR2150 is out of production....still waiting to hear back. Anyone else?
    Here's their specs and features:
    Outlaw RR2150
    State-of-the-art stereo receiver inspired by the art deco table radios of the past
    High performance FM Stereo/FM/AM tuner
    Multiple inputs with separate record output bus
    USB input for playback of streaming audio output from compatible computers
    High quality phono input for both moving magnet and moving coil cartridges
    Processor/equalizer loop
    The only stereo receiver with a subwoofer output that includes selectable, analog bass management
    Front panel "speaker equalization" selector adds a half-octave of bass boost at a choice of frequencies to improve performance with compact bookshelf speakers
    Headphone jack with level control
    Front panel stereo mini-jack input for easy connection to portable devices such as iPod?
    Tone control defeat
    Precision, motorized volume control
    A/B Speaker Output
    Pre-Out/Main-In connections
    IR In/Out jacks
    Removable IEC style power cord
    Multi-device, programmable remote control
    Specifications
    Audio Section
    Continuous Average Power:
    100 watts per channel, 20 Hz - 20kHz,<0.03% THD, both channels driven into 8 ohms
    160 watts per channel, 20 Hz - 20kHz,<0.03% THD, both channels driven into 4 ohms
    Input Sensitivity/Impedance:
    High Level: 200mV/47kohms
    MM Phono: 3.3mV/47kohms
    MC Phono: 0.6mV/47kohms
    S/N Ratio: 96dB
    Bass Management:
    Adjustable 60/80/100/Bypass
    High-Pass Slope 12 dB/octave (2nd order)
    Low-Pass Slope 12 dB/octave (2nd order)
    Tone Control:
    Bass Center Frequency/Range 50Hz ? 6.5dB
    Treble Center Frequency/Range 1KHz ? 6.5db
    FM Tuner Section
    Frequency Range: 87.5-108MHz
    Usable Sensitivity IHF: 12dBf
    Signal-to-Noise Ratio:
    Mono/Stereo 75/70dB
    Stereo Distortion: 0.24%
    Stereo Separation: 37dB @ 19kHz
    Selectivity: +/-10kHz, 70dB
    AM Tuner Section
    Frequency Range: 530-1710kHz
    Usable Sensitivity: 500uV/M
    Signal-to-Noise Ratio: >54dB
    Selectivity: +/-10kHz >25dB
    General
    Supply Voltage 120V, 60Hz only
    Power Consumption:
    5W Idle
    400W maximum, both channels driven
    Dimensions:
    (HxWxD) 5.75 x 17.1 x 15 in.
    Weight 27 lbs
    Yamaha R-S700
    Specs
    Specifications
    ToP-ART Technology Yes
    RMS Output Power 100W x 2
    iPod Compatibility via Yamaha Universal Dock 1 (for optional YDS-12, YID-W10 or YBA-10)
    XM Satellite Radio Ready Sirius Satellite Radio Ready
    Pure Direct Switch Yes
    Switchable CD Direct Amplification Yes
    THD [0.04%]
    Linear Damping Factor (Speaker A) 240 or more
    Continuously Variable Loudness Control Yes
    40-Station Preset Tuning Yes
    Pre-Out / Main-In Coupler Yes
    Zone 2 Output Yes
    Zone Remote Control Yes
    IR Ports 2 In / 1 Out
    +12V Trigger Output Yes
    Product Dimension (W x H x D) / Weight (lbs.) 17-1/8? x 6? x 15-1/4? / 24.7
    R-S700 Natural Sound Stereo Receiver
    Elite class stereo receiver combining ToP-ART technology and ART Base chassis construction with gold?plated speaker terminals and dual aluminum heat sinks for crisp, clean sound. Advanced features include continuously variable loudness control, CD Direct Amplification, along with Yamaha iPod dock connection, SIRIUS Radio Ready, 40-station AM/FM and zone 2 control for endless music enjoyment options.
    MAIN FEATURES
    Dual aluminum-extruded heat sinks ensure effective heat dissipation and help achieve crisp, clean sound.
    Gold-plated speaker terminals and RCA in/out jacks are durable and provide highest quality connections.
    With a straight connection to the CD input, CD Direct Amplification maximizes CD source S/N ratio.
    An iPod Dock port provides highest quality sound from an iPod. iPod Video Out allows connection to a TV.
    With a subscription to SIRIUS Satellite Radio, you can greatly expand your choice of high quality radio programs.
    This receiver makes it easy for someone in another room to listen to the music and even control playback.
    Advanced Features
    100W x 2 high power output
    ToP-ART (Total Performance Anti-Resonance Technology)
    40-station AM/FM random access preset tuning
    Pure Direct for short and direct signal path
    Speaker A, B or A+B selection
    Subwoofer Out
    Rec Out selector
    Pre-main coupler
    Power management (Auto power off)
    Terminal for detachable AC cable
    Preset and Zone 2 remote controls
    Dimensions (W x H x D): 17-1/8" x 6" x 15-1/4"
    Zone Control
    Multi-Zone Compatibility
Wouldn't it be nice to be able to enjoy your favorite music in more than one room? The R-S700 has a number of specialized functions that make it convenient to use in custom installations. With another receiver or amplifier plus a pair of speakers in a second room, the people in both rooms can hear the music that is playing. You can even put a pair of speakers in a third room and listen there as well. What's more, you can control playback of the main system from the second room with the Zone 2 remote control.
    12V Trigger Out (Control Out)
The 12V trigger output can be used to automatically power on the components in Zone 2 when the main power is turned on. Output is a high 100mA, so relay operation is possible.
    Main/Zone 2 Power Link
When you switch on the R-S700 in the main room, the unit in Zone 2 will also come on.
    Remote (IR) 2 In/Out and Remote 2 In
These terminals let you connect an IR signal receiver for wireless remote control between the Main Zone and Zone 2.
    Speaker A/B and A+B Selection
Enjoy music in a third room! Just connect a second pair of speakers to the Speaker B terminals and you can listen to either pair or both of them at the same time.
    Dedicated Zone remote Control
The R-S700 provides a second remote unit for controlling operation of the main system from Zone 2.
    The Look and Texture of Quality
Offers the look and feel of the top-class A-S2000, with elegant aluminum front panel and silky touch volume/selector knobs. You can feel Yamaha's commitment to quality when you touch the knobs.
    ToP-ART Sound Quality Design
ToP-ART (Total Performance Anti-Resonance Technology) design uses a symmetrical layout for accurate sound field reproduction and the ART Base to eliminate effects from external vibration.
    Pure Direct
Music signals travel the shortest possible route, bypassing the buffer amp and tone, loudness and balance controls to virtually eliminate any signal degradation for the purest sound quality.
    New Speaker Terminals
These high grade speaker terminals have gold plating for best connection and outstanding durability. The pitch between jacks is wider for easier insertion.
    Highest Quality Parts
The quality of each individual part, as well as how they work together, basically determines the sound quality of any component. Yamaha uses only very high quality parts, carefully selected and tested.
Our ears lose sensitivity to high and low frequencies at low volume levels. This control lets you turn down the volume while maintaining the optimum frequency response.
    Special Power Supply for Clear iPod Sound
The iPod dock has an independent power supply to prevent operating or charging current from the iPod from flowing into the amp ground signal. This ensures optimum iPod sound quality.
    Balanced System for Minimal Noise
An unbalanced interface is subject to commonmode voltage noise, so Yamaha uses a balanced system to receive the iPod signal. This makes a significant contribution to reducing noise in the system for higher sound quality.
    New Remote Controls
The R-S700 preset remote control is designed to make it easy to operate the receiver's many functions. The R-S700 provides a second remote that allows system control from Zone 2.
    __________________
    Styx
  • gdb
    gdb Posts: 6,012
    edited June 2012
    Can either be heard by you prior to purchase? Are they easily returned if they end up sounding like a$$? On looks alone....my vote is for the Outlaw, hands down !:cheesygrin: I don't think I'd know how to act with a remote controlled receiver ! (or preamp for that matter !):wink:
  • styx
    styx Posts: 37
    edited June 2012
    Not able to give them a listen to prior to purchasing. It seems those days are gone, at least in my area.
    Styx
    EndersShadow Posts: 17,704
    edited June 2012
    erniejade wrote: »
    I really really really like that you can select the hz for bass management on the back. Not only that its there, but its BEFORE the amplifier. So your ONLY amplifiying the remaining frequencies for your fronts if your using a sub. I do not think this is the way a standard AVR does things.
    I have read LOTS of reviews of that outlaw model and they are all pretty favorable. Its supposed to punch WAAAAAYYY above its pricepoint. Plus right now on the used market its hard to find that good a deal.
  • Drenis
    Drenis Posts: 2,871
    edited June 2012
    Parasound's New Classic line has this feature built into their amps. Great feature.
  • styx
    styx Posts: 37
    edited June 2012
    cnh wrote: »
    cnh
    Just heard back from Outlaw and RR2150 is still part of their current line up. I may become an "Outlaw". :lol:
    Styx
  • styx
    styx Posts: 37
    edited August 2012
    I took the plung and got the RR2150 during the sale. Got it setup last nite and listen for a hour or so....so far I'm very happy with it. The volume controls on the remote are a little touchy but this little receiver packs a bunch. Good solid bass, the highs are clear but not too bright. It's a good solid performer that I'll have for a long time.:mrgreen:
    The only thing I miss is the loudness control on the Sansui. I used it all the time at low levels. I've had many receivers over the years with loudness controls that never sounded good to me, so I never used them but the Sansui was the exception. The RR2150 has a "speaker equalization" selector that adds a half-octave of bass boost at a choice of frequencies to improve performance which helps.
    It's nice to have a modern receiver to add in the rotation.:smile:
    Styx
  • zingo
    zingo Posts: 11,258
    edited August 2012
    Great looking unit; congrats!
  • Conradicles
    Conradicles Posts: 6,342
