WTB, buy or borrow!
starkiller
Need to buy or borrow a very very cheap preamp, just need it to check out which MA500's don't work. The Denon integrated that i was going to use does not have pre/out main/in like I thought it did. local would be fine
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Post edited by starkiller on
use the CD player as source to check...I know GCD700 had variable output which can be hooked up to an amp...
or 1/8" stereo to RCA connector from mp3 player would work too...
or use a DVD player laying aroundVideo: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
Yeah, your Adcom should have varible outputs, I know my GDC-600 does. That'll work.
Umm, i guess i be dumb..you guys are saying to just run a variable output cd player to the ma500??Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
Yeah, that should work. Or as devani said, mp3 player with a mini to RCA cord.
starkiller wrote: »Umm, i guess i be dumb..you guys are saying to just run a variable output cd player to the ma500??
...anything with a volume control and a RCA output, or a RCA adapter. Headphone jack out of a computer is another option.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Well, i am going to be doing this testing in the garage so the computer is out, I guess i could also use the headphone jack out of the cd player also eh?
wow, after all these years i guess i do learn something new every day:eek:Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC -
starkiller wrote: »...I guess i could also use the headphone jack out of the cd player also eh?
If your CD player has RCA outs, why would you use the headphone jack? Is that the only way to control the volume?2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
And just a quick FYI:
Whatever variable volume device you choose to use, make sure the volume is all the way down before connecting it or playing any music... then start playing and increase the volume gradually.
Will do, THAT much I do know after a rather unfortunate experience with some nice vintage Crown equipment:redface: Will be using an orphan Denon/Mission speaker for the testing...Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
I have a passive preamp you can borrow to test if you want another option; good luck.
