shm sacd vs mofi sacd
erniejade
erniejade Posts: 6,321
edited June 2012 in Music & Movies
It looks like mofi has or is coming out with some stuff that is also available on shm sacd. If you had to choose between mofi sacd or shm sacd, what would you choose?
Post edited by erniejade on
  • BlueFox
    BlueFox Posts: 15,250
    edited June 2012
    How do we know it is not the same data, and just on a different label? Did they specifically say we took the original and made it better?
  • decal
    decal Posts: 3,205
    edited June 2012
    My SHM's sound significantly better than my MFSL's. But I guarantee you somebody will say just the opposite. You just have to hear for yourself.
    F1nut Posts: 52,011
    edited June 2012
    Are both using the same mastering?
  • erniejade
    edited June 2012
    I believe mofi re-masters all of them themselves but, the shm versions of the sacd, not sure.
    I know there is definately a difference on SHM vs redbook regular cd. The shm sounds much better but, i also have a lot of mofi stuff and now some that i am looking at are on both so what to choose. The SHM versions on cd Japan doesnt say too much about the mastering.
    Toolfan66 Posts: 18,194
    edited June 2012
    I enjoy both!!
  • headrott
    headrott Posts: 5,496
    edited June 2012
    What Jesse said. That is an important question. If you had an MFSL mastered SHM SACD that would be ideal. Those do not exist however.
  • Danny Tse
    Danny Tse Posts: 5,206
    edited June 2012
    MoFi's SACDs are generally cheaper ($30.00 vs. $50.00+) and contain a CD layer. Mofi's a better value.
