Need a new Cordless Drill
audiocr381ve
audiocr381ve Posts: 2,588
edited June 2012 in The Clubhouse
I'm sick of the one we have now. The rotation is a little lopsided and it's just ready to retire. It's a Durabuilt and has never became my best friend.
I'm on a budget but will push it to get something that will last. Does anyone have any recommendations? Preferably something I can pick up from Lowe's or Home Depot?
Post edited by audiocr381ve on
  • Systems
    Systems Posts: 14,872
    edited May 2012
    Do a search, I think Doro asked this same question a year or so ago.
    My vote for the money would be Ryobi.
    Testing
    Testing
    Testing
  • audiocr381ve
    edited May 2012
    pepster wrote: »
    Thanks, just pulled up that thread.
  • gdb
    gdb Posts: 6,012
    edited May 2012
    Avoid DeWalt......like the plague !! They've gone straight down the toilet, albeit in a circular motion ! :lol: Rigid has the best warranty for inexpensive driver/drills, Panasonic is the BEST, but, very pricey.:wink:
  • Systems
    edited May 2012
    If I had your MASSIVE amounts of cash reserves Shane, I would have one custom made!:lol::lol:
    Testing
    Testing
    Testing
  • kcoc321
    kcoc321 Posts: 1,788
    edited May 2012
    Alot depends on what you are going to be using it for and your budget.
    IF you are needing something to drive 3" Framing screws, then I love my Porter Cable 19.2v's.
    Had them for years and all I have had to replace are batteries.
    Medium job duties, I have a 14.4v Hitachi Cordless drill and plus a impact for driving screws ect...
    (FYI: Impacts are the sheit for driving screws )
    Small duty, I have a pocket size 10.8v Bosch driver that is great for just driving screws, has suprising torq and will fit in your pants pocket :)
  • audiocr381ve
    edited May 2012
    You're not drinking again, are you pep!? Haha
    I'm just going to try some out at Home Depot and see which one "speaks" to me ;)
  • headrott
    headrott Posts: 5,496
    edited May 2012
    I bought a Bosch from Lowe's a little over a year ago. Never had a problem with it and it's powerful and works great! It's model number 36618 and is a lithium ion rechargable cordless drill. I couldn't find it on Lowe's web site anymore however, so they may carry a newer model only. There are other places on the net that still have it. I recommend Bosch.
    Edit: I just noticed that Home Depot carries that model, but wow has the price gone up since I bought it. I think I got it on sale for $99.99. I hope this helps.
  • Systems
    edited May 2012
    gdb wrote: »
    But then again they are "Man Tools".
    Only FOOLS that have never used one would say that.
    Children should not use tools, and should not have a say in such "MAN" things.
    Look at the reviews, and then get some insight.
    Beats listening to the 3 letter "TARD".:wink:
    Testing
    Testing
    Testing
  • gdb
    gdb Posts: 6,012
    edited May 2012
    Chinese ****,and I read about and use tools extensively. The reviews say it all, and say it much better than you. Stick the "tard" language up yer.....:rolleyes:
  • Systems
    edited May 2012
    gdb wrote: »
    We may be talking about a different "Tool" here my friend.:lol:
    You might want to check out some other forums at this point.
    Testing
    Testing
    Testing
  • obieone
    obieone Posts: 5,077
    edited May 2012
    Milwaukee, Makita, Dewalt(xrp) Craftsman are good. Stay clear of B&D, Ryobi, Porter Cable.
    If you can get by with a corded, go that route, and save some $.
    edited May 2012
    Bosch would get my vote, Milwaukee too. Seems to me alot of these power drills all have innards made by the same companies so I wouldn't expect a big difference. Battery life is key to a cordless, along with balls, so do your research and find one that fits your needs.
  • Systems
    edited May 2012
    +1000, thats the way to go if you can.
    Testing
    Testing
    Testing
  • Dabutcher
    Dabutcher Posts: 2,633
    edited May 2012
    Makita is my power tool of choice. Never had any issues. Most people like having the second battery so you always have one charged for projects. I would say stay away from craftsman power tools. Great hand tools. Iffy power tools. Poor battery life and chuck always comes loose. Good luck. D
  • drumminman
    drumminman Posts: 3,396
    edited May 2012
    Bought a Porter Cable 19.2V 10 years ago and it's never let me down. Great drill driver.
    Be sure and get one that comes with two batteries so you can be using the drill while one's charging.
  • Zeros
    Zeros Posts: 940
    edited May 2012
    Check this out, stolen from slickdeals. $160 for a Bosch 18v Hammer drill with 4 batteries. Great deal and a great brand.
    Bosch 18-Volt Compact Tough Hammer Drill Driver with 2x-1.5Ah Batteries + 2 Extra SlimPack Batteries (HDS181-02) $160 Free shipping from Amazon
    Automatic $40 Off seen at checkout. Use rebate for 2 Extra Batteries
    Complete the job with ease with the BOSCH Best Built Compact Tough 18-Volt 1/2-Inch Lithium-Ion Hammer/Drill/Driver Kit. It is ready for all materials including concrete, wood and metal. Enjoy the benefit of having the lightest, most compact and most comfortable heavy duty 18V Lithium-Ion drill with Bosch. A powerful and highly efficient 4-Pole motor delivers top performance with strong power and runtime maximizing your efficiency on the job site. This hammerdrill/drill/driver works will all of Bosch 18V Lithium-Ion batteries and chargers for maximum versatility. This kit includes a convenient 30 minute lithium-ion charger, two Slim Pack 18-Volt HC Lithium-Ion 1.5Ah batteries with built-in fuel gauge and tough hard case.
    4-pole high performance motor provides maximum power in a compact size
    New patented gear train and clutch enables compact design and light weight
    Flexible power system, both DD and HDD are compatible with every 18v Li-Ion Bosch battery
    Ergonomic grip zone enables better gripping and greater comfort
    Ergonomic design provides modified orientation relative to handle, increases comfort
    Bosch HDS181-02 18-Volt Compact Tough Drill Driver with 2 1.5Ah Batteries + 2 Extra SlimPack Batteries $160
    Rebate for 2 Extra Batteries
    http://slickdeals.net/f/4645316-Bosch-18-Volt-Compact-Tough-Hammer-Drill-Driver-with-2x-1-5Ah-Batteries-2-Extra-SlimPack-Batteries-HDS181-02-160-Free-shipping-from-Amazon
    That all being said, I own Makita 10.8 v drill, impact, vacuum and flashlight as well as a Milwaukee M18 set with a drill, impact, flashlight, circ. saw and sawzall. I like both lines, but if I had to choose again, I would go with the Milwaukee M12 series for smaller tools since there are so many different tools available now. I would probably stick with with the Milwaukee M18 series for larger tools or get the Bosch I posted above, since I think Bosch tools are some of the nicer ones, just usually more expensive.
    heiney9 Posts: 25,630
    edited May 2012
  • maxima
    maxima Posts: 143
    edited May 2012
    There are many good choices listed above.
    Just a little FYI, TTI is the parent company of Ryobi, Ridgid and Milwaukee. Ryobi is their entry level line, Ridgid is their midline and Milwaukee is the top dog. I have tons of Ridgid tools (Home Depot brand) as their Lifetime Service Agreement is hard to pass up (it even covers batteries) and the tools have held up well.
  • dcmartinpc
    dcmartinpc Posts: 844
    edited May 2012
    I have a set of the new DeWalt 20v LiON tools and they are amazing. I just built my entire basement with them and they always had power to spare and the batteries last a LONG time. The best part of the 20v LiON system is that the batteries typically charge to %100 in about 30 minutes! I have the Hammer Drill, Impact Driver, Reciprocating Saw, and circular saw and I am %100 happy with all of them and couldn't recommend them more highly.
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2012
    I like both Dewalt and Milwaukee. Have been using both their brands for years with great results.
  • DaveHo
    DaveHo Posts: 3,584
    edited May 2012
    I've got a bunch of the Hitachi 18V cordless tools. Couple of drills, circ saw, recip saw, flashlight. Battery life is good & I haven't had any of the batts crap out on me in 5+ years. Cheaper than some of the competition, but made just as well. If you're comfortable buying re-con tools, check out this place for great deals, http://bigskytool.com/
    -Dave
  • Face
    Face Posts: 14,340
    edited May 2012
    Festool.
  • Willow
    Willow Posts: 11,339
    edited May 2012
    Still really like my Milwaukee, 18v 2x Lion battery and rapid charger. The thing has so much torque that my wrist moves sometimes.
  • shawn474
    shawn474 Posts: 3,052
    edited May 2012
    I have ryobi, black & decker, bosch, dewalt and craftsman. Craftsman is junk as is the Black & Decker. The Bosch and DeWalt are vastly superior. Yes, I know Black & Decker owns DeWalt, but they are nowhere close in terms of quality and durability. I have the DeWalt XRP Hammer Drill and it has outlasted every other one and NEVER given me a problem. There hasn't been a job that it couldn't take care of and the batteries still hold the charge 3 years later. I would spend the extra money and get either DeWalt, Bosch or Milwaukee as they will likely outlast the other brands 2 or 3 times over.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • DMara
    DMara Posts: 1,434
    edited May 2012
    Zeros wrote: »
    I bit this deal last week. I've just sent out the rebate form for those 2 additional batteries.
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • Jstas
    Jstas Posts: 15,001
    edited May 2012
    I grabbed a Milwaukee 18V hammer drill for doing the drywall and other fun stuff in the basement and eventually, the kitchen. I've been beating it up with the hammer drill feature and the screw gun feature and it's taken it all like a champ. I also have an impact driver that came with the "kit" and I picked up an Impact Gun. The battery powered impact guns from most makes used to be junk. Only one worth anything was the $600 Snap-On. That was about 8-10 years ago now. Since then, leaps and strides and this Milwaukee impact gun is as good as that old Snap-On ever was. It's a friggin' beast and made short work of my U-joint replacement task. It's comparable to a 1/2 inch air driven impact gun.
    Advice, if you're getting a cordless tool, go for a brand that has other tools that you would see yourself wanting/needing in the future. That way you only need one charger and one type of battery. BTW, get at least 2 batteries. I would get 4 if you are going to use them alot. Certain brands get good reviews, others don't. So find a brand that has all the options you want for a price you want to pay and a decent set of reviews. Milwaukee was all that for me and since I have a few of their corded tools and have been immensely happy with them, I went with them for the cordless tools and I've been equally happy.
    As far as reviews go, the "worst tool ever! This is junk!" and "best tool ever! This is what Jesus would use!", ignore those reviews. They are useless. You want to read the reviews that show people actually doing stuff and what they are doing with the tools. I find that often, the best and worst reviews are from people who are not using the tool for it's intended purpose, like using a screw gun to drive 10" long lag bolts into pressure treated 6x6's or drilling holes in masonry or they are using an impact driver to stick screws in the wall to hang pictures. Those kinds of reviews are useless. Find the guy who is talking about refinishing a home or building a swing set for his kids. Those are real world reviews and typically are practical and reasonable reviews.
    Expert Moron Extraordinaire
    billbillw Posts: 8,102
    edited May 2012
    I'm a big fan of Hitachi power tools. I've had one of their 18V cordless drill models (older NiCad version) for about 6 years now. It is still chugging along and just powered through me putting about 1200 backer board screws down into the tile job that I'm doing at our new house. It didn't complain much at all, although the batteries don't last as long as they used to.
  • Jstas
    Jstas Posts: 15,001
    edited May 2012
    obieone wrote: »
    I have a corded drill and honestly, depending on what you are using it for, it's not a screw gun. If I tried to use it to screw drywall to the wall, I'd be burying the screws an inch in to the studs with it. I know there are corded screw guns out there but they are as rare as hens teeth anymore 'cause everyone is going cordless. So unless you need the power of a corded drill to make lots holes in things, a cordless is a good compromise. Besides, they are getting so good anymore that there isn't much of a difference.
  • Jstas
    Jstas Posts: 15,001
    edited May 2012
    Oh, BTW, one other thing, hold the drill in your hand. Some of the "better" tools are dreadfully balanced and will cause fatigue if you are using them for a long time. That sucks when you can barely hold the drill in place while trying to get that last sheet of sheet rock up.
  • gdpeck
    gdpeck Posts: 840
    edited May 2012
    Jstas wrote: »
    I don't know what the OP is planning on using, but I purchased this Ryobi corded Clutch Driver http://www.ryobitools.com/catalog/power_tools/drills_drivers/D47CK a few years ago, and it has been fantastic for me. I previously had a 12 volt DeWalt, and had issues with the batteries not keeping a charge after very few cycles (user error). I'm an occasional drill user, and the ease of not having to worry about whether a battery is charged or not, and just being able to plug in and go, far outweighs the inconvenience of having to get out an extension cord. It was cheap too. ($40). I'm not arguing against cordless if your frequency of use merits it.
