Sweet - Schiit DAC & Joule Preamp
PreCd
PreCd Posts: 786
edited May 2012 in 2 Channel Audio
Memorial Day is being good to me. Brother brought over his Schiit Bifrost DAC and Joule LA-100 Tube Preamp. We are using a Marantz CD5004 as a transport and have everything running through a Adcom GFA-555 amp along with my SDA TL2Bs. What a difference the preamp makes. The Joule has such a great soundstage, detail, and liveliness that my GFP-565 does not have. Of course there is about $1,500 difference in the two so it should make quite a bit of difference. We also have been playing with the USB port on the Bifrost to PC. It really sounds good and makes me realize that listening to music on a PC is definitely a reality and can sound good. Great even. A very fun day in the air conditioning (95 degrees here).
SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp
Post edited by PreCd on
  • george daniel
    george daniel Posts: 12,096
    edited May 2012
    damn fine pre amp!!
  • thsmith
    thsmith Posts: 6,082
    edited May 2012
    +1 on the preamp. The Schiit DAC has a lot going for it.
  • PreCd
    PreCd Posts: 786
    edited May 2012
    We are still burning in the Schiit DAC but like what we hear so far. The USB interface to the PC sounds decent. I guess I need to start checking into using my PC as a music server as a alternative to my CDP. I can now see the pros of doing so.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • chumlie
    chumlie Posts: 8,658
    edited May 2012
    Nice brother, maybe he'll leave it there for a while.
  • PreCd
    PreCd Posts: 786
    edited May 2012
    Not a chance! Leaving tomorrow and then back to my same old system...........:neutral:
    chumlie wrote: »
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
    nooshinjohn Posts: 26,064
    edited May 2012
    I understand that DAC is the Schiit.
    Let us know what your impressions are.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited May 2012
    The Schiit is a very good DAC, and they've got an even better one in the works. My biggest problem with the Bifrost is their somewhat half-assed implementation of USB. They're not a big fan of USB and while their implementation is decent, it's not great. They will tell you (and they're correct) that the spdif input is better than the USB. If playing files from a computer, having a good usb to spdif converter in the mix is really a necessity.
  • PreCd
    PreCd Posts: 786
    edited May 2012
    We were just discussing that last night....the USB to SPDIF convertor. Do you happen to have some suggestions? And yes I read on their website about their USB connection and their dislike of it. Not just theirs but USB in general I believe is what they were talking about.
    So far so good on the DAC. Transport from my CD5004 sounds good via SPDIF. Some recordings from the PC sound better than others and is the result of the ripping process, computer not being dedicated, some settings, and other factors I am sure. We are still experimenting with it a bit and he will continue to do so when he arrives back at home.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • AsSiMiLaTeD
    edited May 2012
    Yeah those guys are a bit old school in that they haven't embraced USB yet. I happen to disagree with them on that point, I think USB can be properly done if the work is put into it.
    There are several converters on the market. My Musical Fidelity V-Link does a superb job, but have heard the the Audio-GD model is very good as well.
  • doctorcilantro
    doctorcilantro Posts: 2,028
    edited May 2012
    M2tech is a great bang for the buck. Coax or bnc options. But you'd even surprised by some motherboards with coax out. In some case inboard could best a sub-par USB implementation.
    For Sale 2019:
    Tortuga Audio LDR passive preamp
    Decware EL34 amp
    Allnic H-1201 phono
    Zu Union Cubes
    iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
  • PreCd
    PreCd Posts: 786
    edited May 2012
    You would not happen to like guacamole would you? :wink:
    Thanks for the heads up and I will take a look at the M2tech.
    SDA2BTL
    Marantz CD5004
    Adcom GFA-545
  • organ
    organ Posts: 4,969
    edited May 2012
    That looks great. I love the look of the pre. I'm sure it sounds fantastic.
