Playing 78's??
rromeo923
rromeo923 Posts: 1,513
edited May 2012 in 2 Channel Audio
My father has a large collection of 78's he is giving me.
Now what to play them on. He has an old Victorola that doesnt work.
Question?
Should I get the Victorola fixed or buy a new used one?
Should I get an old Console that can play 33,45,and 78's
Should I get a turntable that plays all three.
Question?
Do you need a special needle just for 78?
Thanks!
I got static in my head
Post edited by rromeo923 on
  • madmax
    madmax Posts: 12,434
    edited May 2012
    There is nothing like listening to old 78's on a Victrolla. Keep in mind the records should say victrolla on them, later 78's are not meant for the heavy arm assembly/big needle and will be destroyed on the first play. An old standard issue school phonograph works well, sounds good and doesn't destroy the newer records. There is also the option of one of the new DJ turntables which has 78rpm and a variable speed control. I play with all three versions depending on my mood and type of record. The best cheapest option was the school type phonograph.
    Vinyl, the final frontier...
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited May 2012
    Some of the older idler wheel Duals have the 78 speed. I use a Dual CS-5000 for mine. If you have some early Rock & Roll 78s you may wish to check their value before playing them.
  • gdb
    gdb Posts: 6,012
    edited May 2012
    Just be sure to use different Stylii for 33 1/3 & 78 rpms records !!!:eek:
  • mcnarus
    mcnarus Posts: 20
    edited May 2012
    I had an old Technics belt-drive modified to play 78s. But the easiest thing to do is get a new table. I think the Audio-Technicas play 78s. You will need a different stylus for 78s, as gdb said.
  • gdb
    gdb Posts: 6,012
    edited May 2012
    I found a new one that accepts 78s :cheesygrin:
    http://www.amg-turntables.com/
  • Turbota
    Turbota Posts: 255
    edited May 2012
    That AMG is really a pretty nice looking record player!
    Unfortunatly, no price shown on there webpage ... but I am thinking more than $199.95
    :razz:
    2-Channel Audio
    Onkyo ... A-9050 . . .Integrated Amp. (Power Amp Section not Used)
    Onkyo ... M-282 . ... Power Amps .(Pair)
    Onkyo ... C-7030 . _.CD Player
    Polk . . *. RTi A7 - ....Front Speakers
    Polk . . *. RTi A3 - ....Rear Speakers
    SCompRacer Posts: 9,121
    edited May 2012
    If you can find one reasonably priced, Lenco made an idler drive four speed table that does 78.
