Tannoy D100 cap upgrade.... To mod or not to mod?
thetawave2
thetawave2 Posts: 268
edited May 2012 in DIY, Mods & Tweaks
Hey guys. I read somewhere on here that around 20 yrs old, speakers tend to benefit from replacing the capacitors. My Tannoy D100s, having been produced in the mid nineties, are coming up on that birthday fairly soon. I was wondering how difficult it would be for a first-time speaker modder to upgrade the capacitors. Would it be worth buying a soldering iron and my time and effort? Is there anything else I could do in there fairly easily while I'm at it (e.g. resistors)?
Although I haven't done any work with electronics in the past few years, I did use a soldering iron for some simple projects back in my tech classes in middle school, so it's not a foreign concept to me. And, I'm no electrical engineer but I do have a good grasp of the basics from my physics class. If the project would give me a good return so far as performance, I'd definitely be willing to read up on it, do a bit of research, shop around for the caps, et c.
My Stereo: Tannoy D100s, Yaqin MC-100B, VPI Traveler, Dynavector 10x5 MC Phono Cartridge, heavily modified Yaqin MS-22B phono preamp, TEAC EQA-20 equalizer, Belkin PureAV PF30 Power Conditioner, Canare 4s11 speaker cables, Custom dust cover from DigitalDeckCovers
Post edited by thetawave2 on
  • thetawave2
    edited May 2012
    I also have a pair of Polk Monitor 40s I could practice on, if a practice run would offer valuable experience....
  • thsmith
    thsmith Posts: 6,082
    edited May 2012
    I think they would beneifit. My SDA 1Cs certainly did.
    F1nut Posts: 52,008
    edited May 2012
    The first thing you need to know are the values needed. Do you have a schematic? If not, pull a crossover to see if you can obtain the values for the caps and resistors.
  • Face
    Face Posts: 14,340
    edited May 2012
    Tannoys generally have very simple crossovers, give it a try.
  • zingo
    zingo Posts: 11,258
    edited May 2012
    As above, I would suggest it redoing the crossovers because they are so simple on those speakers and the benefits should be more apparent and cheaper than complex crossovers.
  • thetawave2
    edited May 2012
    I don't have a schematic and I doubt I'll be able to find one online. Doesn't seem to be much info on these babies on the 'net.
    I haven't yet gotten into the guts of my speakers. Anything I need to be careful of when pulling the crossover, or can I pretty much just undo the screws on the rear panel?
  • thetawave2
    edited May 2012
    I got a schematic directly from Tannoy! I do know basic electronics, like the symbols for capacitors, inductors, and resistors seen in this diagram. I'm sure it will make sense when I pull the crossover and have something real to match it up to. This looks like a very simple project.
    So what would I be looking to upgrade? I hear talk of replacing capacitors all the time and sometimes upgrading resistors. Anything else to the project?
  • Face
    Face Posts: 14,340
    edited May 2012
    I would lean towards leaving the inductors alone unless you know the exact DCR of the woofer coil and it's not an air core.
    As for caps, I'd recommend the Claritycap ESA. Tannoy uses them, along with the MR and SA in some of their current speakers. I believe some high end KEF models use them too.
  • thetawave2
    edited May 2012
    Face wrote: »
    Yeah I thought so too haha
    Thanks for the recommendation on the caps!
    By the way, here's the schematic I got from Tannoy.
  • Face
    Face Posts: 14,340
    edited May 2012
    Like I said, cheap, simple schematic.
    For the LF circuit, you can use a single 18uf cap instead of the 10+6.8, it's within tolerance and may be cheaper. If there isn't one readily available, then the 10+6.8 combo is fine. Their server is currently down, but check out Madisound for prices and availability.
  • thetawave2
    edited May 2012
    I undid the rear panel of my speaker just to have a look and I was able to identify the components of the crossover. Doesn't look too intimidating.
  • slider2828
    slider2828 Posts: 118
    edited May 2012
    I just did some cap upgrades..... and I would more lean towards with Mundorf Supreme Caps with some Clarity Cap SA's or ESA's....
    http://www.humblehomemadehifi.com/Cap.html
    This linked helped out a lot.
  • slider2828
    edited May 2012
    thetawave2 wrote: »
    But you are going to do direct connect and breadboards right? Cause its not going to be remove and replace cause more expensive caps are much bigger.
    Take a look at the VR3 Fortress mod thread to give you some ideas.
  • Face
    Face Posts: 14,340
    edited May 2012
    IMO, Mundorf caps are not as good as ESA's.
  • slider2828
    edited May 2012
    How did you feel about the mundorf supremes?
  • thetawave2
    edited May 2012
    slider2828 wrote: »
    I figured the upgraded caps would be bigger but I didn't know they could be THAT much bigger. I'll have to look at the dimensions and the thread you suggested, too!
  • Face
    Face Posts: 14,340
    edited May 2012
    They're a step up from Dayton, but nothing special. Not really a fan of the S/O either, it was a slightly more refined Solen cap for a lot more money.
  • thetawave2
    edited May 2012
    I've calculated the project to be $110 for ESA caps (if I do take one 18u cap as "close enough" to the 16u8 pair of caps specified in the schematic) versus $64 bucks with SA caps. Any idea of the performance difference I can expect if I go with the ESA over the SA?
    Also, my amp has a fairly "hard" top end. Is there anything I can do with resistor or cap replacement in the HF network that might "soften" or "sweeten" the treble a little?
  • Face
    Face Posts: 14,340
    edited May 2012
    ESA's will have tighter bass and better imaging.
    I would usea Mills resistor to help mellow things out.
  • thetawave2
    edited May 2012
    Face wrote: »
    I do like imaging and tight bass.... Is it enough of a difference to justify paying almost double, do you think? I'm really on the fence for ESA vs SA....
    Thanks for the recommendation on the resistor, too!
  • Face
    Face Posts: 14,340
    edited May 2012
    Yes, it's definitely worth the extra $.
  • thetawave2
    edited May 2012
    Face wrote: »
    If I'm gonna do it, might as well do it right I guess! ESA it is.
    I found Mills resistors on Parts Express. The schematic calls for a 2.2 ohm resistor, but it appears Parts Express stocks 2 or 2.5 ohm resistors, and not 2.2 ohms. Should I do a couple in parallel to try to get closer to 2.2 ohms, or should I call it "close enough" with one they have?
    I really appreciate all the input on this!
  • Face
    Face Posts: 14,340
    edited May 2012
    Sonic Craft carries a 2.2ohm. http://www.soniccraft.com/mills_resistors.htm
  • thetawave2
    edited May 2012
    Great! Thanks. This might not be happening in the next few days, but I'm really excited.
