Favorite SDA?
  • Joe08867
    Joe08867 Posts: 3,919
    edited May 2012
    My list would be in order.
    1. 2.3TL
    2. 2B's with the TL mod (Best for more intimate settings).
    3. 1C's or SRS2's
    4. CRS+ with 4.1TL mod
  • newrival
    newrival Posts: 2,017
    edited May 2012
    heiney9 wrote: »
    Yep, subs with SDA's are overkill unless you are set-up in an extremely gigantic room.
    that's your own misguided opinion.
  • falconcry72
    falconcry72 Posts: 3,580
    edited May 2012
    So I was looking at the schematics for the 1.2TL's and the 2.3TL's, and, please bear in mind I am not an electrical engineer, but it looks like the 1.2's have all four stereo drivers crossed over the same and all four dimensional drivers crossed over the same, whereas on the 2.3's the two dimensional drivers are crossed over differently, and, out of the four stereo drivers, two are crossed over the same, and the other two are crossed over differently.
    Is this correct? Does it explain some people's preference for the 2.3's?
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited May 2012
    I currently own the 2A's (stock), 1C's (stock), SRS's (somewhat modded), and 1.2TL's (stock). Of all of these I prefer the dimensional effect of the 1.2TL's the most but prefer the tonal balance of the 2A's by far over the rest. My least favorite (by far) is the 1C's. I would love to try a small set of the SRS's. I think their simpler design with wider driver spacing and larger passive would probably be the sweet spot for my ears. maybe one day I'll know for sure. Good luck and enjoy!
    F1nut Posts: 51,817
    edited May 2012
    Sub? I don't need no stinkin' sub.
    Seriously, the bass response is already deep, tight and shakes the room. I hear no reason to add a sub.
    heiney9 Posts: 25,451
    edited May 2012
    newrival wrote: »
    How is it misguided? Have you heard my rig to even evaluate whether YOU think I need a sub? Properly set up and properly powered it isn't necessary to add a sub to get a full range of music out of most SDA's, the CRS being one obvious exception and perhaps the 2B, but I think are capable as well, but not to the extent the SRS2's, 1C's and so on up the line.
  • falconcry72
    edited May 2012
    nevermind, this is wrong.
